Mechanical oil pressure guage. https://www.ausmini.com/forums/viewtopic.php?f=2&t=10220 |
Author: | sociallydisabled [ Wed Aug 17, 2005 5:51 pm ] |
Post subject: | Mechanical oil pressure guage. |
is it possible to fit one of these to the beast, if so how and where. |
Author: | miniron [ Wed Aug 17, 2005 6:10 pm ] |
![]() Its fitted into the oil gallery in place of the oil pressure light switch. If you wan't to keep the light as well as the gauge, which is a good idea, you need to use a T piece so you can connect the gauge and the oil pressure light switch. Not 100% sure but I think the thread in the block is 1/8" BSP parallel fastening thread so you need an adapter with this thread. Regards RonR |
Author: | awdmoke [ Wed Aug 17, 2005 6:11 pm ] |
Simply unscrew the oil pressure switch & screw the fitting for the gauge tubing straight in. Some universal gauges come with a couple of brass bushes to suit different sender/switch sizes in different cars. Just make sure everything is nice & tight. Hot engine oil squirting out from under the dash is not nice ![]() |
Author: | sociallydisabled [ Wed Aug 17, 2005 6:18 pm ] |
is the switch thing just up and to the left of the dizzy? cos thats a pretty big hole.... ![]() |
Author: | aaron [ Wed Aug 17, 2005 6:25 pm ] |
the hole for the sender is no bigger than the hole for th water temp sender. in fact there the same diameter. I woud recomment putting a t or y peice in as if you don't your oil pressure warning light will never go off ![]() Cheers Aaron |
Author: | sociallydisabled [ Wed Aug 17, 2005 7:02 pm ] |
there was never anything connected to it... |
Author: | Morris 1100 [ Wed Aug 17, 2005 7:06 pm ] |
I always keep the oil pressure light as well as having the gauge. I fit a 25psi oil light switch so the light comes on before the bang not during the bang. ![]() |
Author: | doogie [ Wed Aug 17, 2005 7:55 pm ] |
Yellow engine YUK ![]() Doogie Just my opinion, i say go with Cooper S metallic green ![]() |
