It is currently Fri Jul 18, 2025 9:34 am
 Post subject: Oil change frequency
PostPosted: Thu Feb 29, 2024 6:10 pm
Given that I do not drive the mini much more than 3000k a year I tend to look at the oil and decide when to change it rather than a set km or time.
That being said does oil deteriorate over time rather than with mileage?
And having done a search on here I notice there is an old wives tale about the original mileage for oil change being 1500m. All the literature I have seen says 6000m so where did the 1500m figure come from?
Cheers Dave.
 Post subject: Re: Oil change frequency
PostPosted: Thu Feb 29, 2024 6:35 pm
From my reading on the subject, yearly for low mileage cars seems to be the consensus.
Mk 1 Cooper S 1965
If you could erase all your mistakes of the past
You would also erase the wisdom of your present
Remember the lesson not the disappointment.
PostPosted: Thu Feb 29, 2024 6:53 pm
Apparently the oil does deteriorate and can go acidic over time. How much it really matters is the argument, this recently came up in a Facebook group I am in (not for minis). It was basically a mix of opinions.
I would probably change it yearly for something I care about.
There is stuff I use which hadn't had an oil change for at least 20 years (TEA20). No sign of issues. It did finally get changed.
Test... Don't Guess
PostPosted: Thu Feb 29, 2024 9:39 pm
68+86auto I'm with you on this. i have a similar story with my 1960's Nuffield diesel tractor. It is possibly a story put out by oil suppliers in order to sell more oil.
