It is currently Sun Aug 10, 2025 2:33 am
 Post subject: Brake booster fitting
PostPosted: Wed Aug 17, 2005 9:48 pm
I am going to fit a booster in JAM, mainly because I have one and it's something to do :lol:
You need a hose from intake manifold to booster yea? Also, do you plumb the fluid line from master cylinder to booster, then from here to wheels?
PostPosted: Wed Aug 17, 2005 10:12 pm
pointy end of booster is mounted pointing up a bit, for bleeding.
Line from that end goes to brakes, line near vacuum can runs from MC.
If you have tandem MC, you only boost the front circuit.
<edit> vac line comes from manifold. There's a check valve in the fitting at servo.
PostPosted: Wed Aug 17, 2005 11:10 pm
J_A_M... I suggest you don't fit the brake booster in your car.
I reckon you should put it in a postage box and send it to me so I can put it in mine. :P
Users browsing this forum: Bing [Bot] and 85 guests
