It is currently Tue Jul 08, 2025 1:29 pm
 Post subject: Paint mixing
PostPosted: Tue Apr 23, 2024 4:26 pm
Anyone know a shop that can mix off the Dulon paint code?
Dan
 Post subject: Re: Paint mixing
PostPosted: Tue Apr 23, 2024 5:32 pm
I’ve had acrylic paint mixed for 2 Minis based on Dulon paint codes by John’s Paint Shed at Hemmant, Brisbane.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue Apr 23, 2024 6:03 pm
Yep, I've tried but this code does not come up at John's unfortunately :cry:
PostPosted: Tue Apr 23, 2024 6:11 pm
That’s a shame, I have also had them match paint for me based on a good quality painted part, e.g. backed of a number plate holder which hasn’t seen the Sun.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Tue Apr 23, 2024 6:35 pm
In case you aren't aware there's a folder of paint and trim colour documents here - viewtopic.php?f=25&t=66469
Also, here's a list of PPG current paint codes - viewtopic.php?f=25&t=98953
PostPosted: Tue Apr 23, 2024 6:42 pm
Online
It is better to take a sample to be matched as there are so ,any variables such as tints changing and colours altering that a code paint may not match anyway.
Cheers Dave.
PostPosted: Tue Apr 23, 2024 7:59 pm
Yep, John's son? (I think) said to bring in a panel to match. Unfortunately only the metal under the dash vinyl is the original colour and I cant remove it from the car (Its been painted white).
I just saw winnabeys post, I wish I had have seen that before - hopefully I will be able to match from that.
PostPosted: Tue Apr 23, 2024 8:00 pm
I'll try the PPG codes - thank you!
PostPosted: Tue Apr 23, 2024 8:02 pm
Yep, still trying to find a photo of a Mini in Shale Green. Unfortunately for me only the metal under the dash vinyl is the original colour and I cant remove it from the car (Its been painted white).
Dan
PostPosted: Tue Apr 23, 2024 8:05 pm
I use Harts Industrial Paints Geebung. They haven't yet failed to find a mini colour unlike who I tried previously. Johns paint shed uses the same paint system last I knew (Concept) so should have the same database.
It might be under BMC or Leyland for example not Morris.
Too many minis
PostPosted: Tue Apr 23, 2024 8:47 pm
Thanks. I'll see how I go with the PPG code
