3D Printing - Designs, Tools and Ideas https://www.ausmini.com/forums/viewtopic.php?f=2&t=102296 |
Author: | Mearcat [ Wed May 08, 2024 1:42 pm ] |
Post subject: | 3D Printing - Designs, Tools and Ideas |
I have designed various 3D printed tools and items to help me out during my Mini restoration and since 3D printers seem ubiquitous, I thought it would be great for the community to have a thread where we can share links. If you have your own, or find any designs that you'd like to share, please post them. Some of my designs (from my Printables profile https://www.printables.com/@Mearcat/models) : Door clamp - This tool helps hold the door while fitting/adjusting them. Suits wind-up and sliding window models https://www.printables.com/model/250164-classic-mini-door-clamp ![]() Panel gap tools - Simple tool for setting car panel & door gaps https://www.printables.com/model/244897-car-panel-gap-gauge-tool ![]() Rear quarter window sanding block - Sandpaper holder for sanding quarter window post-rust repair https://www.printables.com/model/696693-classic-mini-rear-quarter-window-sanding-block ![]() Flexible sanding block - for sanding car panels or anything curved https://www.printables.com/model/505709-flexible-sanding-block ![]() Door hinge templates for aligning hinge holes new A-panels https://www.printables.com/model/871604-classic-mini-external-door-hinge-templates-for-a-p |
Author: | Steam [ Wed May 08, 2024 1:51 pm ] |
Post subject: | Re: 3D Printing - Designs, Tools and Ideas |
Fantastic Alan, I have made heaps of special tools for the minis but never 3D printed ones.(Puts hand up as a 3d printer Ludite). Thanks for sharing. |
Author: | Mearcat [ Wed May 08, 2024 2:14 pm ] |
Some others I've found while searching for Classic Mini related prints (I can't of course guarantee that any of these will work, or match your model Mini) SU HIF44 Air Cleaner Elbow https://www.thingiverse.com/thing:5733101 Gauge holder allow extra gauges to be added to a Cooper S 3 clock binnacle https://www.thingiverse.com/thing:5913417 Seat Belt cover https://www.thingiverse.com/thing:3018522 Centre binnacle extension piece for a tachometer like the old Broadspeed type https://www.thingiverse.com/thing:4710094 Case for a 12v power adaptor which fits in the ashtray space in the upper dash pad https://www.thingiverse.com/thing:1638494 Gearbox spring and ball tool for synchronizer assembly https://www.thingiverse.com/thing:3838125 or https://www.thingiverse.com/thing:5371649 Gearbox Double Roller Bearing Removal Spacer Tool https://www.thingiverse.com/thing:3838110 Wheel Bearing Installation Tool - install the outer rings of new wheel bearings for disc type minis https://www.thingiverse.com/thing:3838122 Clutch Slave Filler - Pre Verto versions https://www.thingiverse.com/thing:6531954 Sun visor mounting brackets https://www.thingiverse.com/thing:5324057 Demister vent https://www.thingiverse.com/thing:5371986 Starter motor plug - magneti marelli pre-engaged starter https://www.thingiverse.com/thing:4942483 Door lock plinth/surround https://www.thingiverse.com/thing:4940208 Clutch oil seal tool https://www.thingiverse.com/thing:4600947 Phone holder (replaces dashpad ashtray) https://www.thingiverse.com/thing:2203204 LHS heater tube https://www.thingiverse.com/thing:3969645 CZH628 B-pillar striker blanking cover plate https://www.thingiverse.com/thing:4680972 123ignition electronic distributor seal https://www.thingiverse.com/thing:4841962 Cup holder - attaches to front seat bracket https://www.printables.com/model/480988-classic-mini-cup-holder Steering column indicator/blinker holder https://www.printables.com/model/859028-classic-mini-blinker-holder String method clips for DIY toe check https://www.printables.com/model/757603-classic-mini-string-method-tracking-front-clips |
Author: | mattsmadmini [ Sun May 12, 2024 9:58 am ] |
Mearcat wrote: Some others I've found while searching for Classic Mini related prints (I can't of course guarantee that any of these will work, or match your model Mini) SU HIF44 Air Cleaner Elbow https://www.thingiverse.com/thing:5733101 Gauge holder allow extra gauges to be added to a Cooper S 3 clock binnacle https://www.thingiverse.com/thing:5913417 Seat Belt cover https://www.thingiverse.com/thing:3018522 Centre binnacle extension piece for a tachometer like the old Broadspeed type https://www.thingiverse.com/thing:4710094 Case for a 12v power adaptor which fits in the ashtray space in the upper dash pad https://www.thingiverse.com/thing:1638494 Gearbox spring and ball tool for synchronizer assembly https://www.thingiverse.com/thing:3838125 or https://www.thingiverse.com/thing:5371649 Gearbox Double Roller Bearing Removal Spacer Tool https://www.thingiverse.com/thing:3838110 Wheel Bearing Installation Tool - install the outer rings of new wheel bearings for disc type minis https://www.thingiverse.com/thing:3838122 Clutch Slave Filler - Pre Verto versions https://www.thingiverse.com/thing:6531954 Sun visor mounting brackets https://www.thingiverse.com/thing:5324057 Demister vent https://www.thingiverse.com/thing:5371986 Starter motor plug - magneti marelli pre-engaged starter https://www.thingiverse.com/thing:4942483 Door lock plinth/surround https://www.thingiverse.com/thing:4940208 Clutch oil seal tool https://www.thingiverse.com/thing:4600947 Phone holder (replaces dashpad ashtray) https://www.thingiverse.com/thing:2203204 LHS heater tube https://www.thingiverse.com/thing:3969645 CZH628 B-pillar striker blanking cover plate https://www.thingiverse.com/thing:4680972 123ignition electronic distributor seal https://www.thingiverse.com/thing:4841962 Cup holder - attaches to front seat bracket https://www.printables.com/model/480988-classic-mini-cup-holder Steering column indicator/blinker holder https://www.printables.com/model/859028-classic-mini-blinker-holder String method clips for DIY toe check https://www.printables.com/model/757603-classic-mini-string-method-tracking-front-clips Some good ones in there that i hadnt come across! Awesome stuff. I made an entire set of dimple dies with 100% infill (took 40h of printing) but worth it. Other stuff like vice jaws and small tool holders has made working in the shed that much nicer. |
Author: | timmy201 [ Sun May 12, 2024 11:48 am ] |
Does anyone with a 3D printer have the capacity to print me a few things at my cost? |
Author: | Hobson [ Mon May 13, 2024 9:02 am ] |
I have a few others that aren't up anywhere if anyone needs them too. ![]() ![]() ![]() ![]() |
Author: | mattsmadmini [ Mon May 13, 2024 10:25 am ] |
anyone drawn up a mk1 cowling in CAD? |
Author: | mattsmadmini [ Mon May 13, 2024 2:24 pm ] |
timmy201 wrote: Does anyone with a 3D printer have the capacity to print me a few things at my cost? Yeah potentially Timmy, what are ya after? |
Author: | winabbey [ Mon May 13, 2024 2:48 pm ] |
The 3D printing topic now has its own folder - viewtopic.php?f=65&t=102302 |
Author: | timmy201 [ Wed May 15, 2024 10:22 am ] |
mattsmadmini wrote: timmy201 wrote: Does anyone with a 3D printer have the capacity to print me a few things at my cost? Yeah potentially Timmy, what are ya after? I’ve made my own stl file and trying to refine the design. I’d also be interested in one of the ram pipes linked above |
Author: | kirby [ Fri May 17, 2024 12:23 am ] |
If anyone is interested in this stuff this guy is really cool https://www.youtube.com/@MakingforMotorsport He builds his car for competitive motorkhana |
