RATIOS & SPEED https://www.ausmini.com/forums/viewtopic.php?f=2&t=102318 |
Author: | cooperess [ Mon May 27, 2024 5:25 pm ] |
Post subject: | RATIOS & SPEED |
I have a diff ratio in my Mk2 of 3.1, how many RPM do I need to do in order to travel at 60KPH in 4th gear? My tyres are 145 x 80 Nankangs. Is there a formula? |
Author: | timmy201 [ Mon May 27, 2024 6:07 pm ] |
Post subject: | Re: RATIOS & SPEED |
Use this website - with: 145 tyres 3.1 diff 60kph = 37.5mph 37mph is at 2000rpm, so 37.5mph is 2027rpm http://www.guess-works.com/Tech/ratio.htm |
Author: | ausdino [ Mon May 27, 2024 7:20 pm ] |
Gearcalc is good informative calculator. Free download and you can use it for other cars. Can calc in imperial or metric. I used it when building my westfield 7 clone. Very handy ! |
Author: | simon k [ Mon May 27, 2024 7:57 pm ] |
cooperess wrote: Is there a formula? of course there is!! distance (mm) times distance per minute (km) over distance per revolution (mm) times diff ratio times gear ratio = engine revolutions per minute (1000000*60/60)/(((145*80/100)*2 + (10*25.4)) * pi)*(59/19*1) = 2033.81rpm What's more interesting though is that I put a 3.1 diff under my new motor, and my standard mk2 S speedo is as near to perfectly accurate as you could hope for. I did 100km or so on Saturday afternoon doing my ignition timing and the GPS on my phone was spot on with what the speedo indicated. Dad has a 3.1 under his MK1 S, and it's the same, absolutely accurate, no fiddling with speedo drive ratios (6/17) or modifying speedo gearing/springs/whatever Previously I had a 3.44 under mine, which was a fair way off - the speedo said I was doing 100mph, but the GPS speed it was only about 90 - any other speed had similar % errors I reckon the 1312 TPM on the MK2 speedo face is wrong - I think it's meant to be 1280 like a MK1 |
Author: | slacko [ Mon May 27, 2024 8:41 pm ] |
Does anyone know the TPM of an Australian clubman GT speedo ? Thanks |
Author: | simon k [ Mon May 27, 2024 9:26 pm ] |
slacko wrote: Does anyone know the TPM of an Australian clubman GT speedo ? Thanks it ought to be the same as a MK2 S - 3.44 diff, 6/17 drive gear, 120mph indicated - all the same, but how correct it actually is... pfft |
Author: | 1071 S [ Tue May 28, 2024 10:23 am ] |
The "standard" ratios are 16.4 mph/thousand revs for 3.44 diff; 18.1 for 3.1 ..and I think 14.6 for 3.76 These were the factory specs with standard wheels/tyres... And don't forget to calibrate you nacho as well as the speedo. Speedo is calibrated by altering the distance between the drive and driven wheels in the speedo itself (but i leave it the pros to actually do it.. ![]() My speedo was calibrated years (decades?:) ago for a 3.44 diff. Since then I've swapped to a 3.1 ..and installed a good tacho which I trust to keep me legal... The figures in Timmy's table above pretty well match my "settings" (although I have 165 tyres). Cheers, Ian |
