Brake booster fitting https://www.ausmini.com/forums/viewtopic.php?f=2&t=10233 |
Author: | J_A_M [ Wed Aug 17, 2005 9:48 pm ] |
Post subject: | Brake booster fitting |
I am going to fit a booster in JAM, mainly because I have one and it's something to do ![]() You need a hose from intake manifold to booster yea? Also, do you plumb the fluid line from master cylinder to booster, then from here to wheels? |
Author: | drmini in aust [ Wed Aug 17, 2005 10:12 pm ] |
pointy end of booster is mounted pointing up a bit, for bleeding. Line from that end goes to brakes, line near vacuum can runs from MC. If you have tandem MC, you only boost the front circuit. <edit> vac line comes from manifold. There's a check valve in the fitting at servo. |
Author: | Molina [ Wed Aug 17, 2005 11:10 pm ] |
J_A_M... I suggest you don't fit the brake booster in your car. I reckon you should put it in a postage box and send it to me so I can put it in mine. ![]() |
