It is currently Fri Aug 01, 2025 2:24 am
 Post subject: wheel Bearing Q's
PostPosted: Wed Aug 17, 2005 9:58 pm
I've started building up my new cooper S hubs tonight.
In the manual and exploded diagrams there is mention of a thin spacer ring between the inner wheel bearing and the inner oil seal.
In the wheel bearing kit I bought there are two wheel bearings (cup and bearings in two sets) , two oil seals, 1 metal spacer ring which is smaller in inner diameter than the bearing, and a white translucent plastic ring...Surely that is not the spacer ring they refer to is it?
I would have thought that the plastic ring would melt if used in the hub. Anyone out there experienced this?
KB
PostPosted: Wed Aug 17, 2005 10:18 pm
The white ring is a water & slush thrower. Sits nearest engine. Useful in UK. PITA here...
The bit you are missing is a spacer ring, looks like a piston ring. Might have to get from Padstow. If you can't get I can probably make some.
PostPosted: Wed Aug 17, 2005 10:40 pm
Thanks Doc,
'll try the usual suspects tomorrow.
Any chance of making those shock absorber spacers instead?
I cleaned up some brackets and shocks I got from pick'n'payless on the weekend, so the shocks should be ready to go on this weekend with the brakes. :P
KB
PostPosted: Wed Aug 17, 2005 10:51 pm
No problem I'll make some on sat.
PostPosted: Thu Aug 18, 2005 1:16 pm
Kev how'd you go finding these....
I need 2 aswell cause mine are busted 8)
[Maverick] 1971 Mini K
PostPosted: Thu Aug 18, 2005 5:47 pm
getting them couried from Padstow and haven't arrived yet, BUT, they say they are just some sort of engine ring that they use nowadays as the real spacers are NLA.
I have to grind 1/8" off one side (of the gap) to increase the gap in order to be the right diameter and use two per side. The Doc said as much in his post as well.
You may as well experiment and make your own if that's the case. In mine, I would like them by the weekend to fit, so time is short in my case hence placing the order.
KB
PostPosted: Thu Aug 18, 2005 5:58 pm
Thanks Mate...one on mine is good I just need another. The ring was bent when I had my mate press the bearing out.
 Post subject: rehashing
PostPosted: Sun May 20, 2007 1:12 am
Sorry to re-hash such an old thread, I have just picked up the same tapered wheel bearing kit as mentioned. I am using Metro uprights. Do I also need this metal ring?
I noticed that one of the black dust seals has a bit more of a lip on the edge than the other one. Could this possibly nullify (sp) the spacer ring?
Oh and lastly do the tapered shells go in first facing outwards then the inner part just sits inside or does the bearing go into the upright facing inwards? if you get my drift?
Thanks guys
blokeinamoke wrote:
 Post subject: I am ok now
PostPosted: Sun May 20, 2007 1:43 am
I have done a bit more of a search and I think I have it sorted.
Press in both inner races first
grab my CV pop a grease seal on it
Grease up an inner bearing race slide it on the CV
slide CV into hub
slide spacer in
slide outer inner race on followed by seal
assemble and tighten?
Lastly, What stops the inner grease seal from getting squashed when its all tightened?
Thankyou
blokeinamoke wrote:
PostPosted: Sun May 20, 2007 1:48 am
go to bed.....:)
 Post subject: go to bed
PostPosted: Sun May 20, 2007 2:17 am
re. go to bed
I work nights so I kinda lurk around ausmini on the weekends when I cant sleep :evil:
blokeinamoke wrote:
 Post subject: Re: I am ok now
PostPosted: Sun May 20, 2007 9:06 am
slide CV into hub
slide spacer in
Thankyou
Yes you will bugger the seal doing it that way.
The way I do it:
1. press bearing cups into hub.
2. Fit inner (engine side) bearing cone after grease packing it.
3. Fit the piston ring type spacer against bearing.
4. Press the seal against the spacer.
5. Fit the white water slinger if included.
6. turn hub over and fit inner spacer.
7. Grease outer bearing cone and fit. LEAVE OUTER SEAL off.
8. Fit C/V to the assembly, fit drive flange and taper washer, torque nut up to 150lb/t.
9. Spin the C/V in the hub. Check there is no slack in the assembly when rocked about.
10 If it has any endfloat I measure it, remove drive flange, take the inner spacer out and machine off (endfload +.001").
11. Fit the outer seal and assemble.
:wink:
 Post subject: outer seal
PostPosted: Sun May 20, 2007 9:36 pm
does the outer seal stay off?
Or is it just until I tourqe it up and make sure its ok?
aaand where could I get one of these piston ring type spacer? if no one knows where can you make me some doc?
blokeinamoke wrote:
 Post subject: Re: outer seal
PostPosted: Mon May 21, 2007 9:47 am
I leave that seal out only until I check no endfloat. If it does have endfloat the seal has to come out again, so this way I avoid damaging it.
The split spacers were used on both drum brakes and disc, but the disc ones are wider. All it does is ensure the seal misses the CV shoulder and the bearing, and is in straight.
If I don't have any spacer I tap the inner seal in carefully, and leave a gap to the bearing. You can use a steel rule inside the seal, measure off the bearing to ensure seal is in straight. :wink:
