Brake bleading issues. https://www.ausmini.com/forums/viewtopic.php?f=2&t=10237 |
Author: | cazmo [ Wed Aug 17, 2005 10:08 pm ] |
Post subject: | Brake bleading issues. |
hey guys. I'm just having a bit of trouble with my brakes, the pedel is fairly squishy so the other day I decided i would blead the system. On the backs i could only get a trickle of fluid to come out, and i couldn't push the pedel to the floor with the blead nipple undone. it was the same for both sides. when i did the fronts, i could get a lot more fluid out and the pedel would go all the way to the floor. what would cause so little fluid to come out of the rears? i certainly don't think this is normal, but correct me if i'm wrong. Cheers, Cazmo |
Author: | J_A_M [ Wed Aug 17, 2005 10:17 pm ] |
limiting valve on the rear subframe. I have a good bleeding method posted on my website forum. I can't be bothered retyping it..... ![]() |
Author: | Wolfman [ Wed Aug 17, 2005 10:39 pm ] |
Check your rear hoses, trust me I just did mine and the Doc was right the left had closed up tight with age ![]() |
Author: | cazmo [ Fri Aug 19, 2005 9:13 pm ] |
how much would one of those limiting valves be worth? |
Author: | min13k [ Fri Aug 19, 2005 11:57 pm ] |
caz i would go the pipes first they would be the likly problem if they are old makka |
Author: | gafmo [ Sat Aug 20, 2005 12:09 am ] |
Total agree...with Makka and Woffman...but I would then check the Limiter..its time to get a couple of bottles of brake fluid mate ![]() |
Author: | drmini in aust [ Sat Aug 20, 2005 7:03 am ] |
Don't think you can buy the rear limiting valve now, Karcraft don't list the Lockheed seal kit for it any more either. ![]() |
Author: | TheMiniMan [ Sat Aug 20, 2005 1:30 pm ] |
The problem will be the rear hoses,,, it`s nearly allways the rear hoses,,, the pressure limiting valve hardly ever stuffs up,,, & even if it did, normally it would just not work, but would still allow fluid to come through Replace both your rear hoses & bleed it all again & you should be fine Point of warning tho!!!!!!!!!!!....If you go to bleed the front, --->you`ll need to "UN-ADJUST" them,,,then bleed them & then "ADJUST" them back up to do it properly,,,that is unless you have front disc brakes, then just happilly let them gravity bleed away ![]() easy-peasy ![]() |
Author: | cazmo [ Sat Aug 20, 2005 11:50 pm ] |
Thanks guys, I'll changes those rear hoses, re-bleed and see how it goes. Cheers |
