It is currently Mon Jun 23, 2025 5:22 pm
 Post subject: Clubman Door Seals
PostPosted: Thu Aug 08, 2024 2:36 pm
Could anybody share information on the correct door seal for the Australian Clubman GT
Are the door seals the same as a Mk 2 Australian Cooper S regards measurements or completely different?
I have what may be one original door seal on the car but the other appears to be a replacement.
Any help would be much appreciated.
The photos show what I believe is the original door seal.
The other door seal has a much larger bulb on the pinch weld.
Also rear side 1/4 light window seals which look to be the same as the Mk 2 Cooper S - Mk 1 seals?
 Post subject: Re: Clubman Door Seals
PostPosted: Thu Aug 08, 2024 4:39 pm
In this discussion we talked about the original door seals that were used on the Cooper S and the Clubman series.
viewtopic.php?f=2&t=84464
At some point the seal changed to a vulcanised seal and pinchweld combined, part HYE0111. The engineering drawing is dated early 1976 and shows the length as 128 cm.
https://minisport.com.au/products/mini- ... slide-type
