Mike wrote:
You can change the oil yourself, its easy in a mini. The oil drain hole is right at the bottom of the g'box (thats the bottom of the engine). If you are facing the bonnet, its right at the bottom front on the left of the motor. There;s a large plug there facing to your left. Undo it using the correct socket (11/16 I think) and the oil pours out into a container you put under there. Its also good to jack up the right hand side a bit to get a better flow. (Or even better buy some 20/50W oil and take her to a mechanic and ask them to show you how to do it.
Yeah I reakon I'll give it a go.
Re the clutch. As per the good doc. Can you engage reverse without crunching? If yes its not the clutch. If no, does pumping up your clutch pedal a few times make it feel stiffer? If yes its air in the clutch hydraulics or youre low on brake fluid. Take the car to a mech, ask them to bleed the clutch for you and they might as well bleed the brakes.
Most of the time NO....it crunch, sometimes yes. Pumping the clutch HELPS it get into gears without resistance however it doesn't feel like it's changing the feel of the clutch (pressure doesn't change).
I'll have a go today and see what I can see
Cheers for ya help fella's!!
KiwiMR2
