windscreen info
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10345
Page 1 of 2
Author:  t_n46 [ Sun Aug 21, 2005 7:57 pm ]
Post subject:  windscreen info
anyone know of the best (and cheapest) place to get a new windscreen for my Rover (1994). In Victoria
How much do they cost approx?
Thanks.
Author:  willy [ Sun Aug 21, 2005 7:59 pm ]
Insured?
Accidentally break it :wink:
Then you may get a brand newie :D
(read your policy before you do anything tho!)
Author:  t_n46 [ Sun Aug 21, 2005 8:01 pm ]
no, i just bought this car and it has a big chip on windscreen that pisses me off.
Author:  Wolfman [ Sun Aug 21, 2005 8:14 pm ]
Most chips can be repaired so well now days you wouldn't know it was ever there.
Author:  aussie [ Sun Aug 21, 2005 8:20 pm ]
take it to steve at brickworx and get the seals replaced :wink:
Author:  min13k [ Sun Aug 21, 2005 8:22 pm ]
aussie he is in melbourne not adelaide ....... is your brain turning to mush ??
if the chip is not to bad they can inject silicon into it to fix it
makka
Author:  Mini Mad [ Sun Aug 21, 2005 8:50 pm ]
If your insured with shannons they give you 1 windscreen replacement per year ;)
Author:  brickworx [ Sun Aug 21, 2005 9:25 pm ]
I'm retiring from windscreen fitting...
after the big willy incident.
Cost me more than the job was worth.
Author:  willy [ Sun Aug 21, 2005 9:26 pm ]
:D Mini seals good now.
Not a drop inside the car.
Cept the ones from the rooted 1/4 window seals.
Author:  aussie [ Sun Aug 21, 2005 9:29 pm ]
makka
:roll: I was implying if he wanted a new windscreen, he could go and get the seals replaced and get a new windscreen like what happened to will.
Author:  brickworx [ Sun Aug 21, 2005 9:31 pm ]
I told you i'm not touching your car again
Author:  Morris 1100 [ Sun Aug 21, 2005 10:03 pm ]
When i was working in a wreckers I was told to only remove windscreens that were parked in the sun.
The only screen I broke was in the shade, so there may be something in it! :wink:
Author:  Wolfman [ Sun Aug 21, 2005 10:04 pm ]
Hehe, sounds like someone had some dramas getting the bugger to seal :lol: Sounds like the one I put in my old HK had the bugger in and out 4 times trying to get it to seal right, even a pro couldn't do it so I just learnt to put up with it and avoid driving it in the wet :oops:
Author:  brickworx [ Sun Aug 21, 2005 10:14 pm ]
I broke willy's pulling it out. There was so much glue and crap on i pulled one side and the other side stayed in place and broke.
Author:  Harley [ Sun Aug 21, 2005 10:18 pm ]
Where's the chip? If it's behind the mirror or high or low on the passenger side
you might be able to get round it.
