fitting a boot seal https://www.ausmini.com/forums/viewtopic.php?f=2&t=10372 |
Author: | gibovski [ Mon Aug 22, 2005 1:53 pm ] |
Post subject: | fitting a boot seal |
Has anyone had the pleasure of trying to fit a new seal onto the boot lid of a clubman (they might all be the same not sure). Any tips? advice? I got no idea.... |
Author: | h0nk [ Mon Aug 22, 2005 2:04 pm ] |
Well if they're all the same it's really easy, I've done one on a deluxe. Basically just push it on, and it sits there.. But I'm not sure if its the same for a clubman, better wait for a clubby owners advice. |
Author: | gibovski [ Mon Aug 22, 2005 2:20 pm ] |
I was under the impression that some form of adhesive needed to be used? The door seals are easy. They are just push on but the boot is a different monster. |
Author: | fuzzy-hair-man [ Mon Aug 22, 2005 2:31 pm ] |
J_A_M has done one and posted something about it up here: http://www.ausmini.com/forums/viewtopic.php?t=3490&start=0&postdays=0&postorder=asc&highlight=boot The title is not encouraging though ![]() |
Author: | h0nk [ Mon Aug 22, 2005 2:39 pm ] |
gibovski wrote: I was under the impression that some form of adhesive needed to be used?
The door seals are easy. They are just push on but the boot is a different monster. I must have done it the bodgy way ![]() |
Author: | gibovski [ Mon Aug 22, 2005 2:54 pm ] |
Thanks Fuzzy hair man. Think I'll just use adhesive to glue the thing shut after reading that thread. ![]() |
Author: | J_A_M [ Mon Aug 22, 2005 2:59 pm ] |
bah ha ha.....and it is STILL hard to close, although I can close it now! ![]() I have pics of the seal installation......will dig them out. I started at the bottom middle of the bootlid, and used a new original seal and clips to fit it. Position the seal on the boot lid. Look at where the next hole is for a clip, then fit the clip to the seal, then press into boot lid. Push HARD till you hear the clip 'click' into the lid. Repeat for every clip (26 in total I believe). You end up where you started, then just cut the excess seal off. Took me an hour or so (to fit) then half an hour to close the damn boot! ![]() NB: I would much rather my method than glueing! Anything that is stuck tp paint is a NO NO in my opinion. Messy and permanent! ![]() |
Author: | Harley [ Mon Aug 22, 2005 3:07 pm ] |
I think mine has just been siliconed on. If there are clips under there no way will I get the bugger off. Doesn't look as neat, but works very well. |
Author: | Wolfman [ Mon Aug 22, 2005 9:13 pm ] |
Sickaflex is the way to go, sticks incredibly well and is a marine grade. Just make sure you apply the pressure equally when trying to close the boot the first time as it's easy to ding your lid ![]() |
