Fitting the bonnet (yes i know what it does) https://www.ausmini.com/forums/viewtopic.php?f=2&t=1046 |
Author: | cush [ Mon Jul 05, 2004 4:46 pm ] |
Post subject: | Fitting the bonnet (yes i know what it does) |
has anyone got any tips on getting the bonnet to close and open cleanly? because at the moment, it's rubbing pretty roughly against the panel under the front windscreen. i've loosened the bolts on the underside of the bonnet lid and pulled it forward but it still catches.. |
Author: | min13k [ Mon Jul 05, 2004 5:02 pm ] |
loosen enuff that with a little force you can move it then just keep pulling and pushing till it is in the right postion makka hmmmm pushme pullme dr doolittle ?? sounds sexual |
Author: | cush [ Mon Jul 05, 2004 5:07 pm ] |
and if that doesn't work.... then what..... oysters? ![]() |
Author: | min13k [ Mon Jul 05, 2004 6:17 pm ] |
if it toots ya horn makka |
Author: | cush [ Mon Jul 05, 2004 6:21 pm ] |
so basically it's wiggle it 'till it fits...isn't there anything i can bend or hit with a hammer ![]() |
Author: | min13k [ Mon Jul 05, 2004 6:30 pm ] |
well yeah if it make ya wang swing lol um to be honest i think the only adjustment is on the bonnet i dont think you can adjust the hinges makka |
Author: | drmini in aust [ Mon Jul 05, 2004 7:42 pm ] |
You can also adjust the bonnet catch position and height... maybe it's in the wrong spot at the moment. |
Author: | gafmo [ Mon Jul 05, 2004 10:50 pm ] |
One thing I will add. Once you have it correct.. and this is a good one....... Drill two holes in the bars of the bonet staye, size anought for pot rivits with the stem the size inwhich y know.....Drill them and place them in Happy...Cool... Next time you take the bonet off and try it again try it but before tightning the bolts put those same rivets back in Here is a shot ![]() To Big To Small now everbodied a critic not just my wife Hope this help |
Author: | cush [ Tue Jul 06, 2004 10:45 am ] |
microsopes out everybody! ![]() have you got a bigger pic? |
