Disc Brake Conversion https://www.ausmini.com/forums/viewtopic.php?f=2&t=10534 |
Page 1 of 3 |
Author: | Stuwey [ Sat Aug 27, 2005 11:55 am ] |
Well, its almost 11.30 and we haven't heard from you yet... ![]() |
Author: | gafmo [ Sat Aug 27, 2005 12:20 pm ] |
Getting Closer |
Author: | JC [ Sat Aug 27, 2005 12:56 pm ] |
Pardon my ignorance but what breed of brakes are they? And who's Chris....? |
Author: | 68matic [ Sat Aug 27, 2005 1:16 pm ] |
chris is czerial from this forum theyre from Truckstop, Alan who does the Camira brake conversions havent put on my overalls yet... trevor wont start so thats discouraged me ![]() |
Author: | 68matic [ Sat Aug 27, 2005 3:03 pm ] |
Trev wont start: turns over fine no spark at the dissy between the points changed the coil - nothing points and condenser changed 6 months ago, car is driven every 2-3 weeks wiring is all the same from 3 days ago when he started any ideas? |
Author: | czerial [ Sat Aug 27, 2005 3:35 pm ] |
So are they on Duc? |
Author: | gafmo [ Sat Aug 27, 2005 3:41 pm ] |
I guess your tool box is all over the drive wau by now ![]() Do you have a gap in your points..and is the coil crap Also check that wire that goes into the dizzy and points may be earthing |
Author: | 68matic [ Sun Aug 28, 2005 3:28 pm ] |
i dont have any tools left in my tool box ![]() yep points open up on button rotation coils are new bosche gts dissy wires are there, pos and neg what do you mean by points are earthing? and i tried to take off the old brakes yest, dont have a big enough socket for the centre cheesehead nut, and the three little 8mm bolts are kinda rounded i say trev'd better go before i put the stoppers on him |
Author: | Konzo [ Sun Aug 28, 2005 4:24 pm ] |
68matic ... how much did u pay for them? |
Author: | mini_van_1970 [ Sun Aug 28, 2005 5:29 pm ] |
What we did was because the bolts were preety well sheered off too so we got a 7/16 nut and tac miged it there and took it off that way and just replaced the bolts afterwards my 2c Pat |
Author: | Stuwey [ Sun Aug 28, 2005 6:34 pm ] |
Big 'cheesehead' nut should be 1-1/8". For drum brake CVs, that is. Its actually called a 'castelled' nut, but we'll let you off this time. ![]() And the reason it wont start is simple... Its a bloody Mini. Just beause it ran yeasterday doesn't mean anything. ![]() |
Author: | 68matic [ Sun Aug 28, 2005 6:54 pm ] |
luke i paid $500 for the set cheers for the nut/bolt tips im thinking of somehow using an impact driver on the little shits... make some flathead grooves with a dremel and take it out on them ![]() cheers stu ill get it right next time just gotta remember its a rook in chess and a castle in minis ![]() |
Author: | Stuwey [ Sun Aug 28, 2005 7:07 pm ] |
Go take the car to the local Mech. just get him to rattle the nut off, then do it back up with a socket to a reasonable tension again so that you can get it undone when you get home. My mate and i did the same thing for the nuts on the top of his (sigma) struts. Much easier that way. You can lever all you like, but its the shock effect of the rattle gun that gets it undone. |
Author: | 998_Clubman [ Sun Aug 28, 2005 7:51 pm ] |
woot can you take some more pics man? a mate of mine is making a set up for me, just wondering how the studs are mounted.. look slike there just weled to the rotor there hey? with the spacer bolted ? pics please mate ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
