What size is this SU? https://www.ausmini.com/forums/viewtopic.php?f=2&t=10561 |
Author: | Gordo [ Sun Aug 28, 2005 9:45 am ] |
Post subject: | What size is this SU? |
Hey all i have this SU carb.. And i have no idea what size it is..... How can you tell? Cheers Daniel ![]() ![]() |
Author: | aaron [ Sun Aug 28, 2005 9:47 am ] |
1.5 inch, 1.25 is alot smaller and 1.75 has 4 mounting holes onto the manifold. Cheers Aaron |
Author: | mini_van_1970 [ Sun Aug 28, 2005 10:39 am ] |
Yeh it is a 1.5 But where is the throttle jet at the bottom for the choke thingy Sorry guys don't know much about what it is called Pat |
Author: | drmini in aust [ Sun Aug 28, 2005 1:06 pm ] |
Yep it's missing the main jet and tube. But if you overhaul it you get a newie in the kit anyway. |
Author: | Gordo [ Sun Aug 28, 2005 2:52 pm ] |
Thanks guys ![]() Does anyone know where's the best place to get the over haul kit from? And by 'best' i mean cheapest... Cheers Daniel |
Author: | gafmo [ Sun Aug 28, 2005 4:57 pm ] |
Midel's...Speak to Bill Sivertsen (Sivo) 9759 5598,,,,4 frazer Street Lakemba Mention your from Ausmini Will cost you under $25 for a set including Gaskets, Main Jet and Tude...purchased one recently for a HS6 ![]() |
Author: | drmini in aust [ Sun Aug 28, 2005 5:47 pm ] |
Gordo wrote: Thanks guys
![]() Does anyone know where's the best place to get the over haul kit from? And by 'best' i mean cheapest... Cheers Daniel PM MiniK on this site. Well under 20 buckerooz... ![]() |
Author: | J_A_M [ Sun Aug 28, 2005 8:03 pm ] |
Repco, Peps, any spares joint has 'em! Between $20 and $30 - depends where you go. That needle is probably bent too, since it's hanging out the bottom. |
Author: | drmini in aust [ Sun Aug 28, 2005 9:05 pm ] |
p/no of this Fuel Miser kit is SU-750. Does the HS2 and HS4 carbs. ![]() |
Author: | gafmo [ Mon Aug 29, 2005 8:46 am ] |
well spoted thier JAM ![]() |
Author: | Gordo [ Mon Aug 29, 2005 6:00 pm ] |
Yeah i noticed the needle hanging out the bottom as well... Cant complain when you find stuff in the shed you never knew you had... ![]() |
