Upper ball joint boot
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10573
Author:  chasg [ Sun Aug 28, 2005 5:25 pm ]
Post subject:  Upper ball joint boot
Does any one know if the upper ball joint boots for a mini will fit a metro?
The upper boot on my metro disc brake conversion is split
Cheerd chasg
Author:  JC [ Sun Aug 28, 2005 6:29 pm ]
Post subject:  Re: Upper ball joint boot
Cheerd chasg
You wouldn't believe I just threw four second hand ones out would you? I suspect the metro ones are MUCH bigger than the mini one.
Author:  Lillee [ Mon Aug 29, 2005 7:08 am ]
These are really cheap from any place that stocks ball joints or mini parts... Like under $1
Author:  drmini in aust [ Mon Aug 29, 2005 8:39 am ]
Chong these are Metro ones, different to a Mini, I think.. :? Never ever seen one, round these here parts... :wink:
Author:  chasg [ Tue Aug 30, 2005 8:20 pm ]
Apparently you can use tie rod end replacement boots from repco.
They come in 3 sizes. The part nos are TE1, TE2 and TE3.
The one to fit the metro is either a TE2 or TE3. l will buy one of each and try them.
Cheers chasg
Author:  chasg [ Sun Sep 04, 2005 6:23 pm ]
Replaced both upper ball joint boots today. The passenger side boot also had a slight tear. The replacement boots for the metro are the repco TE 3. Cost $6.00 for the pair
Author:  JC [ Sun Sep 04, 2005 8:41 pm ]
And are they much bigger than the mini one?
