My Blocks https://www.ausmini.com/forums/viewtopic.php?f=2&t=10588 |
Page 1 of 4 |
Author: | gafmo [ Mon Aug 29, 2005 8:37 am ] |
Post subject: | My Blocks |
Over the weekend I desided to pull two blocks apart ![]() Here is my 1275 Cooper S and 998/1098 Cranked Blocks both look in great condition...with the bores look nice and smooth..so I think I al luck...the 1275 is + .40 and the 998/1098 is fresh as ![]() As you can see thier are many layers of paint on the 1275 s theyboth will get a good clean up...Should I acid dip them or what ![]() Both cranks seem to have a nice ring to them also...so I will be pleased but I may get them double checked before going back in ![]() that also goes for these little babies ![]() It looks like all bearing need replacing but I would say I was going to do that anyway...just to be safe The 1275 will be put back together again but the 998/1098 may have something else doneto it..but thats a secret for the moment ![]() |
Author: | drmini in aust [ Mon Aug 29, 2005 8:42 am ] |
I'll come & bring micrometer this morning, will check the cranks for wear. ![]() |
Author: | gafmo [ Mon Aug 29, 2005 8:44 am ] |
Author: | GT1360 [ Mon Aug 29, 2005 8:57 am ] |
![]() ![]() ![]() ![]() ![]() Whats the world comming to? ![]() |
Author: | Zizzle [ Mon Aug 29, 2005 9:24 am ] |
Can see the tip your work boot poking into one of those photos there gaf ![]() |
Author: | gafmo [ Mon Aug 29, 2005 9:27 am ] |
Yep it does look like my saftey shoe's were on again ![]() |
I think they need some blinging also... |
Author: | J_A_M [ Mon Aug 29, 2005 9:37 am ] |
whats the part number for a 1275 crank? |
Author: | Lillee [ Mon Aug 29, 2005 9:50 am ] |
hahaha it wouldn't be authentic Jim mini pictures without a toe showing in the picture! Classic! ![]() |
Author: | poeee [ Mon Aug 29, 2005 10:00 am ] |
I wouldn't acid dip the blocks until ya go to rebuilt the engine. Stop it going rusty. |
Author: | gafmo [ Mon Aug 29, 2005 11:13 am ] |
Anton AEG479/480 EN40B cross drilled, nitrided, 1.625" Well they have been inspected by the good Dr The Cooper S Crank as above just needs a polish on the mains only...who ever installed it last time did not put ACL Bearings into..so just a little polish is required. the 1098..is perfect....they both has a very nice ring to them..."ting" so no cracks The 1275 Block need a light Honing and that all..998 block I'll take up to its first step +.20..So all are good Cam is a 1100s so that will get a RE13 grind and so will the standard 998 So as its stands I am very lucky So it will be wire wheel time for both blocks and pass them both on to GR to work his magic..with a little something extra for the 998 block ![]() ![]() |
Author: | drmini in aust [ Mon Aug 29, 2005 11:51 am ] |
J_A_M wrote: whats the part number for a 1275 crank?
AEG479/480 common Mk1 & 2 1275S crank, EN40B material, X-drilled & nitrided 12G1505 big journal 1275 crank (common one here in Oz) EN16 this one can be stroked or destroked if you find a good one... CAM6232 big journal rolled fillet radius, A+ motors. Not good for stroking.. EN16 12G1287/8 for small journal 1275 crank EN16. AEG623 small journal for 1275S, tufftrided EN16- supposedly used in last of Mk2 S. I've never seen one... ![]() ![]() |
Author: | J_A_M [ Mon Aug 29, 2005 12:19 pm ] |
Nice one on the motors Jimbo..... ![]() Kev...so many cranks ![]() Do cross drilled cranks have a double hole on the journals? Like 2 holes in 1? I think I have one of them .... ![]() |
Author: | drmini in aust [ Mon Aug 29, 2005 12:25 pm ] |
Crossdrilled S cranks have 2 holes in the big ends, but the outer hole should have a brass plug in. If it hasn't fallen out... ![]() |
Author: | J_A_M [ Mon Aug 29, 2005 12:37 pm ] |
gafmo wrote: I think they need some blinging also...
yes mate, you should POLISH those blocks! ![]() ![]() |
Page 1 of 4 | All times are UTC + 10 hours |
