It is currently Tue Jul 29, 2025 3:53 pm
 Post subject: Pushrods
PostPosted: Mon Aug 29, 2005 9:55 am
Are 1275 pushrods longer than 998/1098 ?
PostPosted: Mon Aug 29, 2005 11:15 am
crap longer or shorter...I cant rember which way :?
PostPosted: Mon Aug 29, 2005 11:17 am
I believe they are longer by about 10mm
PostPosted: Mon Aug 29, 2005 11:38 am
a Mk 1 S block is higher right? So the 1275 push rods must be longer in theory.....
Looks like I have some :D If they have slight surface rust, can they be sandblasted and still be OK to use?
PostPosted: Mon Aug 29, 2005 11:46 am
I wouldn't sandblast them.
Clean then up with some steel wool or fine abrasive paper.
PostPosted: Mon Aug 29, 2005 11:57 am
yes the 1275S and other 1275s too have longer ones as block is taller.
The small S's (970 & 1071) use the standard short ones.
PostPosted: Mon Aug 29, 2005 12:25 pm
Cool 8) thanks. Have to keep those :wink:
