How is the dash light dimmer switch mounted in a 1275 LS
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10606
Author:  poeee [ Mon Aug 29, 2005 4:53 pm ]
Post subject:  How is the dash light dimmer switch mounted in a 1275 LS
After pix or something about how the dash light dimmer switch is mounted in a 1275 LS.
Author:  czerial [ Mon Aug 29, 2005 5:51 pm ]
MAte, it is mounted the same way as all clubby dimmers. ; )
If no one can help by the time i get home, will post up a pic
Author:  poeee [ Mon Aug 29, 2005 6:07 pm ]
How are clubby ones done? Previous owner has made up a thing for that and a heater tap puller thinga. I've got rid of the heater tap, so dont need the puller thinga, so yer...
Author:  DJG-14U [ Mon Aug 29, 2005 6:44 pm ]
Mine sits on the right hand side of the steering colum.. Its a bit dark now but if no one replies tonight tommorow I will take some pics for you and put them up so you can see where it goes :)..
Author:  LS1380 [ Mon Aug 29, 2005 7:12 pm ]
Post subject:  LS Dimmer Switch
Gidday-On the LS the switch is located on the RH side on the
lower dash pad.It has the letter"P" stamped on the knob.
Allan.
Author:  WhoDat [ Tue Aug 30, 2005 3:24 am ]
Here's Poee a year ago
Have a look here mate - even if the dash has been modded - this has got an original still fiited
Author:  czerial [ Tue Aug 30, 2005 2:34 pm ]
yep very true, thats how it should be mounted!!
