It is currently Wed Jul 30, 2025 11:38 am
PostPosted: Mon Aug 29, 2005 6:07 pm
Are the after market steering boses for the early minis and the clubmans different in length ? If so which is longer ? l know the splines are the same.
Cheers chasg
PostPosted: Mon Aug 29, 2005 7:06 pm
Chasg,
Can't answer your question mate but thought I might just ask you if boss kits include all the parts to connect the spline on the steering column to the bare steering wheel and where is the cheapest place to buy them from. Been quoted $115 from supercrap.
PostPosted: Mon Aug 29, 2005 7:46 pm
I have an early Mini MotaLita one and a later Mini SAAS one. The MotaLita is around 25mm longer- ie the wheel centre is closer to you. :wink:
PostPosted: Mon Aug 29, 2005 7:55 pm
i have heard that the autotechnica ones are pretty long.
1974 Moke - 998cc
PostPosted: Mon Aug 29, 2005 9:14 pm
Chong's running a Volvo one.... :shock:
Took 3mm off the back in the lathe to clear the Mini shroud, it fits the splines perfect! :lol:
PostPosted: Mon Aug 29, 2005 10:01 pm
Clubby are different to roundy, according to Auto One. I believe this applies to Autotechnica.
PostPosted: Mon Aug 29, 2005 11:01 pm
Clubby and late roundy are the same. Early roundy with horn push was different. But splines are the same. If you have the MK2 or later blinkers/headlights/horn switch you can use either.
Users browsing this forum: winabbey and 92 guests
