Mini rear swaybar fitment https://www.ausmini.com/forums/viewtopic.php?f=2&t=10620 |
Author: | minicranks [ Tue Aug 30, 2005 7:28 am ] |
Post subject: | Mini rear swaybar fitment |
Has anyone got a photo of a rear sway bar fitted to a mini. Please if they could point me in the right direction as the instrcutions i got with the sway bar say follow manufacturers instructions, which dont help due to minis not coming out with sway bars originally, i want ot get it right as i have a really good idea on how it fits just not 100%sure on the mounting points at the rear. any kind of photos would help. thanks |
Author: | LS1380 [ Tue Aug 30, 2005 8:36 am ] |
Post subject: | rear sway bar |
Gidday I've got front and rear sway bars fitted.Did you know that on the rear there are two different bars-ie rubber susp or hydro susp. Make sure you got two brackets supplied with your rear bar,which go on the lower shock absorber mount,this attaches the ends of the bar,with the rubber bushes and lock nuts.When you bolt these up-you then see where to drill the rear subframe for the halfmoon shackle clamps and bushes. Hope this is helpful. Allan. |
Author: | 13secmini [ Tue Aug 30, 2005 8:54 am ] |
not sure if these help, its on mine with dry suspension. ![]() ![]() |
Author: | minicranks [ Tue Aug 30, 2005 3:02 pm ] |
ok that helps quite a bit as i always thopught they went around the other way, but hey you learn everyday. yes i have the dry suspension one that fits onto the eyes of the shock absorbers (unlike your one that has a little bracket that it fits to). what ill do is get a photo of mine and try and put it up here so you can see, its a whiteline one but i cant remember the part number right off the top of my head. Any other pics would still help a lot. thanks |
Author: | Curly [ Tue Aug 30, 2005 9:58 pm ] |
This one is a K-MAC bar and it mounts onto a plate attached to the bumpstop mounts on the trailing arm - It must be about 30 years old but still does the trick. ![]() |
Author: | minicranks [ Tue Aug 30, 2005 10:03 pm ] |
I have a funny feeling that this is going to catch on my exhaust when its installed. I will have a good look at it on thursday and see how it fits to my car. It has the same bushes on the ends as both of yours and looks like it fits to the end of the studs for the shock absorbers (dampers) and then onto the sub frame. thanks guys maybe i should make up some brackets to connect them to. |
Author: | LS1380 [ Tue Aug 30, 2005 11:13 pm ] |
Your rear swaybar should be shaped(ie bend)in it so it goes under the muffler and there should be plenty of room,so it does not touch the muffler. However,I did break the muffler mounting while driving to Hay this year,and the muffler dropped onto the swaybar for the intire trip without any damaged. |
