It is currently Sun Aug 10, 2025 7:21 pm
PostPosted: Thu Sep 01, 2005 7:57 pm
My fresh motor build leaks oil. :x ONLY from the side plates. I was pissed off that a 'full gasket set' didn't include seals for the bolts that secure the side plates.
I went to Karcraft today and found out that a 'full gasket kit' is catered for a 998 / 1098 pre 1975. These motors have a shallow groove in the side plate (needing a thin cork gasket), and only need a washer to seal the bolt.
Late 998's, 1098's and ALL Cooper S's had deep grooves in the side plates (needing a thick rubber type gasket) and an 'o-ring' and 'cup' to seal the bolt.
If you don't use these on a late type motor, you will get bad leaks!!! (as I have found out)
So for a mere $12 my motor will now be leak free!
PostPosted: Thu Sep 01, 2005 8:29 pm
So it's not a mini then??
:lol: :lol: :lol:
Bob Slattery
PostPosted: Thu Sep 01, 2005 8:32 pm
Bound to rust underneath now! One less Clubby.... huhu :wink:
PostPosted: Thu Sep 01, 2005 9:07 pm
^ :lol: ^
Lillee - 1969 Morris Mini K
PostPosted: Thu Sep 01, 2005 9:12 pm
Well gooooooooly, you lot are hilarious!
:lol:
PostPosted: Thu Sep 01, 2005 9:30 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey anton now i see the picture of gomer you and him have a disturbing resebalance
makka
PostPosted: Thu Sep 01, 2005 9:42 pm
haw haw haw.... :roll:
Users browsing this forum: No registered users and 147 guests
