Side plate seals - what I learnt today! https://www.ausmini.com/forums/viewtopic.php?f=2&t=10703 |
Author: | J_A_M [ Thu Sep 01, 2005 7:57 pm ] |
Post subject: | Side plate seals - what I learnt today! |
My fresh motor build leaks oil. ![]() I went to Karcraft today and found out that a 'full gasket kit' is catered for a 998 / 1098 pre 1975. These motors have a shallow groove in the side plate (needing a thin cork gasket), and only need a washer to seal the bolt. Late 998's, 1098's and ALL Cooper S's had deep grooves in the side plates (needing a thick rubber type gasket) and an 'o-ring' and 'cup' to seal the bolt. If you don't use these on a late type motor, you will get bad leaks!!! (as I have found out) So for a mere $12 my motor will now be leak free! |
Author: | MrBob [ Thu Sep 01, 2005 8:29 pm ] |
Post subject: | Re: Side plate seals - what I learnt today! |
J_A_M wrote: my motor will now be leak free! So it's not a mini then??
Author: | drmini in aust [ Thu Sep 01, 2005 8:32 pm ] |
Bound to rust underneath now! One less Clubby.... huhu ![]() |
Author: | Lillee [ Thu Sep 01, 2005 9:07 pm ] |
Author: | J_A_M [ Thu Sep 01, 2005 9:12 pm ] |
![]() Well gooooooooly, you lot are hilarious! ![]() |
Author: | min13k [ Thu Sep 01, 2005 9:30 pm ] |
hey anton now i see the picture of gomer you and him have a disturbing resebalance makka |
Author: | J_A_M [ Thu Sep 01, 2005 9:42 pm ] |
haw haw haw.... ![]() |
