68 Van. Side window confusion! https://www.ausmini.com/forums/viewtopic.php?f=2&t=10723 |
Page 1 of 2 |
Author: | ddddave [ Fri Sep 02, 2005 10:11 am ] |
Post subject: | 68 Van. Side window confusion! |
I,ve just bought a 68 van and want to pull out the side windows to patch up and paint. Window rubbers are perished beyond reuse. There is probably a thread on this here somewhere. The confusion I have is this. ![]() Are van windows non-standard ( dealer fitted accesory )? If so: Where to buy the window rubber? And what would the part?product be called? Its a pretty small profile strip by the look of it. Any help on this appreciated. I haven't owned a mini since my P plates. Which was long ago. Getting back into it. |
Author: | J_A_M [ Fri Sep 02, 2005 10:59 am ] |
Welcome. Good question and I don't think we have had this before....well not for ages anyway. I don't have an answer, sorry. Someone will.... |
Author: | Angusdog [ Fri Sep 02, 2005 11:11 am ] |
Do you have a pic? I have a full set of the rubbers from my Clubman van which I don't need. Two on each side. Post a pic and I'll see if they're the same. |
Author: | gafmo [ Fri Sep 02, 2005 1:20 pm ] |
Check out Jill200sx..she's just done allthat ![]() ![]() |
Author: | jill200sx [ Fri Sep 02, 2005 1:35 pm ] |
Sorry Gaf, I removed the windows and filled them in, I think he wants to replace the rubbers and put the windows back in ![]() Any windscreen place should have them though. |
Author: | ddddave [ Fri Sep 02, 2005 3:31 pm ] |
Thanks everyone. angusdog, I'll post a pic for you on saturday, when the boss lets me loose. Yeah I just want to put the windows back in. Though filling in the panel does sound like an interesting option jill200sx. Is it complicated? I hope to do my van up gradually. Its pretty tired looking now. But for $1500 I think its ok. Best feature, rego sticker. |
Author: | aaron [ Fri Sep 02, 2005 3:43 pm ] |
You can use the front rubber and locking strip on the sides. the rear windows are different. Cheers Aaron Fellow Van owner |
Author: | Gordo [ Fri Sep 02, 2005 4:21 pm ] |
I think all vans unless they are a traveller came out without the rear side windows in them, so all of the vans out there that have windows in the side have been cut into them afterwards.... ( i think) |
Author: | Chris [ Fri Sep 02, 2005 9:20 pm ] |
Glass companies are always putting windows in vans, so they would have suitable rubber seals. Glass was put in all mini vans after sale. |
Author: | poeee [ Fri Sep 02, 2005 11:10 pm ] |
Gordo wrote: I think all vans unless they are a traveller came out without the rear side windows in them, so all of the vans out there that have windows in the side have been cut into them afterwards.... ( i think)
I don't think that's true, as the vans with windows dont have that support thing half way down. |
Author: | bnicho [ Fri Sep 02, 2005 11:27 pm ] |
Most vans had the windows fitted by the dealer. Often you can tell where the strengthening bar was cut out top and bottom. Regardless, the rubber was usually an off-the-roll universal type. Clark rubber stock it. |
Author: | WhoDat [ Fri Sep 02, 2005 11:31 pm ] |
You can still see the remnants of my support beam - real botchy job of cutting it out of the way to fit the windows ![]() Anyways - any windscreen mob would be able to replace the rubbers or fit for you. The there is always Clarks Rubber if you want to do it all yourself. Cheers Dat |
Author: | Angusdog [ Sat Sep 03, 2005 6:34 am ] |
Mine still has the support as it has two windows each side, and I think done by the dealer as an option when purchased. |
Author: | IwannaMini [ Sat Sep 03, 2005 6:18 pm ] |
while on the discussion of van rubbers... does anyone in Sydney know where I can get the rubbers for the windows in the back doors (the square windows) and for the actual doors themselves (the seals)... MG Spares dont have either of them... ![]() Also how do you "tighten up" the side windows on a traveller..? They rattle too much for my liking. |
Author: | aaron [ Sat Sep 03, 2005 8:08 pm ] |
IwannaMini wrote: while on the discussion of van rubbers... does anyone in Sydney know where I can get the rubbers for the windows in the back doors (the square windows) and for the actual doors themselves (the seals)... MG Spares dont have either of them...
![]() Also how do you "tighten up" the side windows on a traveller..? They rattle too much for my liking. Scots old auto rubber http://www.scottsoldautorubber.com.au/Morris%201959-72%20Mini%20&%201973-78%20Lelyand.htm It's pretty well the only place other than spectrum(and cheaper inclusive of poastge) to get your rubber needs! ![]() Cheers Aaron |
