Carby Identification
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10731
Author:  rampage101 [ Fri Sep 02, 2005 3:05 pm ]
Post subject:  Carby Identification
I have this carby, just got it for $10 off ebay. But, I don't understand all the extra piping. Its a 1.1/2 SU, but thats as much as I know. Ideas??
Author:  J_A_M [ Fri Sep 02, 2005 3:07 pm ]
fuel return?
Author:  min13k [ Fri Sep 02, 2005 3:13 pm ]
could be from a 6 triple setup the plastick tube is were the stink pipe off the rocker cover or whatever goes to
makka
Author:  rampage101 [ Fri Sep 02, 2005 3:17 pm ]
Umm, ok :?
So, what do I do? Block some of them off?
Author:  Morris 1100 [ Fri Sep 02, 2005 7:03 pm ]
The two hoses to the float bowl are fuel from the pump and the vent to the charcoal cannister.
The hose to the side of the carby is the vac line to the dizzy
The plastic tube into the side of the carb above the float bowl is from the pcv valve.
Author:  drmini in aust [ Fri Sep 02, 2005 7:28 pm ]
Um... it's from the crankcase breather. PCV valve (into manifold)was replaced by this vac line into the SU body. It works, sort-of. Not as good as the old PCV... :wink:
