HELP
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10755
Author:  mini_me [ Sat Sep 03, 2005 7:35 am ]
Post subject:  HELP
I,m in the process of restoring a 1976 clubby.
Does anyone know where the hoses for the carbon canister go to,
I have one going from centre of canister going to rocker cover and the other goes to fuel tank,the third top outlet is not connected.
Does this outlet go to the extra outlet on the carby float chamber?
Also does the small plastic connection on standard air cleaner supposed to have a hose on it or is it just open to atmosphere.
Thanks Felix :?:
Author:  drmini in aust [ Sat Sep 03, 2005 7:49 am ]
Post subject:  Re: HELP
Thanks Felix :?:
On a `76 with the 998, the rocker cover hose goes to canister, one to tank and the other as you said to the float bowl breather.
The PCV circuit is completed by the hose from the crankcase breather to vac port on side of carb.
Author:  mini_me [ Sat Sep 03, 2005 8:07 am ]
Post subject:  HELP
thanks Doc.
Do you know if the small plastic outlet on air cleaner is supposed to be connected to any thing
Author:  drmini in aust [ Sat Sep 03, 2005 8:14 am ]
No I don't think it's used, but on Clubby S prior to 76? (no canister) it went to the rocker cover.
Author:  DJG-14U [ Sat Sep 03, 2005 9:34 am ]
mini_me wrote:
thanks Doc.
Nope its not connected well its not on Granny anyway but everything else is connected bar a missing fan belt on the air pump which is currently seized :(...
Author:  drmini in aust [ Sat Sep 03, 2005 10:05 am ]
If you fix the air pump and put a belt on Granny will have even less power... :lol:
Author:  min13k [ Sat Sep 03, 2005 10:09 am ]
kev granny has heapsa power :D
makka
Author:  DJG-14U [ Sat Sep 03, 2005 10:10 am ]
Thanks Doc for letting me know :)..
I have been told this would be the case.. But I am thinking of only putting the fan belt on in car shows and leaving it off for the rest of the time :)..
I dont want to take off all the pollution gear to keep her original.. Also I knew I would not be a speed or performance freak when I brought Granny. So I will have to keep those desires for when I get another Mini at some stage :)..
