whats your idle speed? https://www.ausmini.com/forums/viewtopic.php?f=2&t=10773 |
Page 1 of 2 |
Author: | h0nk [ Sat Sep 03, 2005 7:53 pm ] |
Post subject: | whats your idle speed? |
Whats everyone set their idle to? I've got twin HS2s with around a 1100cc engine... If I set the idle any lower then about 1100~1200rpm, after accelerating then letting it idle the engine will slow down then stall. So currently it's set to idle at around 1200rpm.. The book says it should be around 800-1000 anyone know whats wrong? |
Author: | NAV [ Sat Sep 03, 2005 7:57 pm ] |
Post subject: | Re: whats your idle speed? |
h0nk wrote: Whats everyone set their idle to?
I've got twin HS2s with around a 1100cc engine... If I set the idle any lower then about 1100~1200rpm, after accelerating then letting it idle the engine will slow down then stall. So currently it's set to idle at around 1200rpm.. The book says it should be around 800-1000 anyone know whats wrong? NAV has a very similar issue atm. Everything was all fine till i put on the lcb extractors and 1"3/4 exhaust. Now my mixtures are all over the shop. And yes it is a ritcher needle i just need to get him onto a dyno to get it sorted 100% Would auto tranny fluid be thicker than sewing machine oil? |
Author: | J_A_M [ Sat Sep 03, 2005 8:15 pm ] |
1115cc, RE13 cam, twin HS2's = 1100 - 1200rpm idle. Anything below that and it's a dog! |
Author: | Mini Mad [ Sat Sep 03, 2005 8:30 pm ] |
Yeap...similar specs to anton..~1200rpm..same with most i've seen, nothing to worry about. |
Author: | Spaceboy [ Sat Sep 03, 2005 10:49 pm ] |
900rpm, with 731 cam, smooth as it has to be less than 1000rpm or it drives me nuts. your problem might include a sticky carby piston/s or maybe fuel surge? |
Author: | Spaceboy [ Sat Sep 03, 2005 10:51 pm ] |
could be too rich aswell, which would make the idle lumpy |
Author: | Maxi23 [ Sat Sep 03, 2005 11:42 pm ] |
1098cc 1 1/2" SU Extractors Idle speed is now sitting comfortably at 1000 to 1100. sometimes drops to 600 - 800...that sounds tough ![]() |
Author: | drmini in aust [ Sun Sep 04, 2005 6:44 am ] |
Both Barney and Ha-Ha idle at 1100-1200. Barney (twin HS4s) sounds cammier than Ha-Ha (45 Dellorto) although Ha-Ha has a bigger cam.... ![]() |
Author: | gafmo [ Sun Sep 04, 2005 6:50 am ] |
yep Morris sits around the 1000-1100 also 1152 Hif44 re13 cams perry extractors 202 head |
Author: | Lillee [ Sun Sep 04, 2005 3:30 pm ] |
Lillee idles at 1100rpm, 1000 and is still ok but 1100 is just nice (1152cc 266 cam, dellorto45) |
Author: | Namibian CAMEL [ Sun Sep 04, 2005 3:56 pm ] |
whats an idle ![]() ![]() |
Author: | Maxi23 [ Sun Sep 04, 2005 4:00 pm ] |
RPM of ure engine when its sitting there when running. no foot on accelerator etc etc Just sitting there with engine idling |
Author: | Zizzle [ Sun Sep 04, 2005 4:17 pm ] |
Don't you want a high idle to help (splash) lubricate the cam, or am I dreaming...? |
Author: | drmini in aust [ Sun Sep 04, 2005 5:03 pm ] |
Zizzle wrote: Don't you want a high idle to help (splash) lubricate the cam, or am I dreaming...?
That's one reason I idle mine at 1000+. ![]() |
Author: | CPOCSM [ Sun Sep 04, 2005 9:06 pm ] |
1200-1300rpm here. Just off topic for one second but still kinda on the idle thing. Arrived at Russell(rustle!!)Offices Thursday morning and Henry decided to chuck a hissy fit and wouldnt idle. Backed into my usual park and popped the bonnet. So much for the "learned" advice saying dellorto's wouldnt ice up - no matter how cold it gets - the dellorto was nearly all white!! Covered in a fine powdering of ice so the innards must have been absolutely caked in it. Wouldnt idle at all and when the ice melted it would only idle at (just)5-600rpm. After a day in the sunny Canberra sun it was good as gold...sorry for the hijack... Hooroo Rob Forsyth Miniot!! |
