It is currently Thu Aug 14, 2025 5:19 pm
 Post subject: I sniff petrol
PostPosted: Sun Aug 28, 2005 1:02 pm
There is a really strong smell coming into our std 850, after about 5 minutes driving. I'll do a little research, but it's hard to tell if it's stronger when cornering or not.
It's coming from the carb ro nearby, so could it be:
(a) worn carb which leaks petrol
(b) something else.
(you can see I haven't done much detective work yet...)
PostPosted: Sun Aug 28, 2005 1:50 pm
If you have a mechanical fuel pump then check that it is not leaking from the cap. I have had 2 minis leak fuel from there.
Is there an visible leaks on the ground if idleing for a while?
1974 Moke - 998cc
PostPosted: Sun Aug 28, 2005 2:18 pm
First thing i'd do is undo the 3 screws on the carbie bowl and check that the float hasn't got a hole in it or if the float valve is working right.
PostPosted: Sun Aug 28, 2005 10:13 pm
Mine did that and found fuel oozing ou tof the Mech fuel pump
PostPosted: Sun Sep 04, 2005 5:09 pm
Just for the record, the smell was coming from a loose float bowl. As it was so loose, the float bowl was tilted back about 30 degrees. So I made it level and tightened it up. So no smell of gas, and no bogging down in corners - it's like a new car.
I was so buoyed up by my success in fixing the mini, I fitted my new horns to the Commer. PARRRRP! But there's a downside to every Fathers' Day. In this case, it was looking after 2 other kids as well as ours. For some reason, our kids are darlings and everyone else's are little pr!cks...
Users browsing this forum: 1071 S and 175 guests
