need help for oil grade
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10817
Author:  shayne [ Mon Sep 05, 2005 5:00 pm ]
Post subject:  need help for oil grade
Hi everyone been reading the forums for a while and decided to join because I need some assistance can anyone tell me what grade oil I will need when I do an oil change on my automatic 88 mayfair.
Any assistance would be appreciated
Shayne
Author:  drmini in aust [ Mon Sep 05, 2005 5:08 pm ]
Factory recommended 10W30, 10W/40, or 20W/50.
In Australia, any name brand 20W/50 is OK.
Don't use anything fancy with additives (like Castrol Magnatec).
The factory warns against this in the handbook and workshop manual.
Author:  shayne [ Mon Sep 05, 2005 5:11 pm ]
thanks alot for the info :D
Author:  drmini in aust [ Mon Sep 05, 2005 5:13 pm ]
I wouldn't use synthetic in it, either. It's designed for mineral oils. :wink:
If you want it to last well, change the oil & filter OFTEN. Like, every 1500 miles max.
I've had a few autos- 2x 1275s (Morrie 1300) and 998 MiniMatic. Keep the oil clean and they are pretty bulletproof.
Author:  poeee [ Mon Sep 05, 2005 8:31 pm ]
Castrol Formula R mineral is my choice. You'll know you're buying the right grade Formula R, as the others are like $60-$70. The right one (25w50) will be under $30. 8)
As said, change your oil often. Don't let it go more than 5000km.
Author:  kasperflipped [ Mon Sep 05, 2005 8:43 pm ]
sorry for the hi-jack but its on a similar topic, when youve changed the oil, do you need to turn the car over a few times with no-spark to get the oil pressure up once again like you do when youve just rebuilt your engine? I was just wondering as ill be doing my first ever mini service on the weekend, ill be doing the whole oil, filter and plugs and i dont wanna mess it up,
thanks
trent
Author:  Spaceboy [ Mon Sep 05, 2005 8:53 pm ]
fill the oil filter with oil before installing it.
put 20w50 in the auto
not gtx3 or anything like that, it ruins the box.
Author:  drmini in aust [ Mon Sep 05, 2005 8:56 pm ]
Um isn't the auto's filter on it's side... bit hard to do. :?
Poeee- "Castrol Formula R mineral is my choice. You'll know you're buying the right grade Formula R, as the others are like $60-$70. The right one (25w50) will be under $30."-
I wouldn't run that in an auto tranny, too thick.. it's the old Castrol GP50.
Stick with 20W/50.. I get Valvoline for $9.95 a 4L can. :wink:
Author:  Spaceboy [ Mon Sep 05, 2005 8:59 pm ]
heh, yeah it is too
i personally dont bother to do it myself
Author:  drmini in aust [ Mon Sep 05, 2005 9:01 pm ]
thanks
trent
No need. Everything is full of oil already.
Author:  poeee [ Mon Sep 05, 2005 9:26 pm ]
Ignor my post then, didn't see it was an auto!
Author:  CPOCSM [ Mon Sep 05, 2005 9:31 pm ]
The people at Supercrap are still selling the valvoline 20w/50 in 10 litre drums for $24.95...
Rob Forsyth
Miniot!!
