It is currently Sun Aug 03, 2025 10:46 pm
 Post subject: water leak
PostPosted: Fri Sep 09, 2005 6:03 pm
Both my minis have sprung a water leak and ironically in the same place.
The water is coming out of the back thermostat housing bolt under the washer.
I've tried filing the hole with sealant and refitting the bolt,still leaking.
I was going to try fitting some fibre washers next.
Anyone else had this problem before,and is it common on minis.
Thanks Felix :shock:
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Fri Sep 09, 2005 6:08 pm
Sounds like you might need a new thermostat gasket and/or housing. I've noticed on some of my spares the alloy it too pitted to seal.
PostPosted: Fri Sep 09, 2005 7:14 pm
Yep Total Agree
PostPosted: Sat Sep 10, 2005 3:33 am
Unless you get rid of the gaskets and use good old silastic - half the mess in quarter of the time and seals perfectly every time
PostPosted: Sat Sep 10, 2005 6:01 am
I use bolts there- this gets rid of the corrosion problem between the alloy and steel studs, as the act of undoing them frees them up. 8)
Users browsing this forum: Tezmini62 and 89 guests
