It is currently Fri Aug 01, 2025 1:37 am
PostPosted: Fri Sep 09, 2005 5:17 pm
When replacing the wings on a mini clubman, does the engine have to be removed or can they be replaced with the engine still in?
DO IT ONCE, DO IT RIGHT
PostPosted: Fri Sep 09, 2005 5:25 pm
You probably can do it with the engine still in the bay, but I'd say it would be easier if it wasnt.
PostPosted: Fri Sep 09, 2005 5:49 pm
I was just asking the question because I thought if I repaired the wings with the engine still in, it will twist the body. But if I could do it with engine still in it will save me a alot of time. But if I have to remove the engine I will.
