It is currently Thu Aug 14, 2025 9:26 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Sep 09, 2005 3:02 pm
My brakes (honda 9") seem 'funny'
The pedal is very firm, yet they don't exactly put my face on the windscreen when I hit the anchors :?
I have driven other Mini's with discs, and they seem to stop better than mine.
So why would I have a hard pedal, yet no more stopping power than Pops with drums all round?
PostPosted: Fri Sep 09, 2005 3:05 pm
Hmmmm. strange.. I got no idea... they boosted?
PostPosted: Fri Sep 09, 2005 3:10 pm
I was going to change the rear cylinders to cooper s ones & fit some green stuff pads.
If I slam my brakes I stop vey quickly.
65 DELUXE
69 DELUXE
MY MINI PICS: http://www.flickr.com/photos/morrie850/
PostPosted: Fri Sep 09, 2005 3:15 pm
Just to help the diagnosis....
New master cylinder. New hoses on all corners. Not boosted. Rear cylinders are standard, but I put kits through them.
Fluid is getting to all 4 corners, and the car does not vere to one side when I brake.
Front pads and rear shoes are all new.
:? wEiRd!
PostPosted: Fri Sep 09, 2005 3:17 pm
Not wierd. Unboosted disc brakes need lots of pedal pressure.
You're just going soft :lol:
Stand on that pedal. That's why Cooper S had a thicker brake pedal :wink:
PostPosted: Fri Sep 09, 2005 3:20 pm
Shouldn't you have the cooper S rear wheel cylinders? They are a different size to standard ones, stops the rear brakes coming on too early or doesn't this apply to dual circuit brakes.
Roads need more corners
PostPosted: Fri Sep 09, 2005 3:21 pm
yes...they did have a thicker pedal!
I can get a booster....original S item. Can you get rebuild kits for them?
How do they essentially work?
PostPosted: Fri Sep 09, 2005 3:25 pm
I don't have dual curcuit brakes.
I did ask Karcraft about S rear cylinders....and they said there wouldn't be that much difference. But your description sounds kinda right....that the rears are working before the front discs.
PostPosted: Fri Sep 09, 2005 3:28 pm
I belive you can get reconditioning kits for them I know you can get the diaphrams.
How they work:
Briefly, the manifold vacumn creates a vacumn on both sides of the diaphram when you push the pedal down a valve is open to atomospheric pressure which rushes in and pushes behind the diaphram once you are done braking the valve is closed and the pressure between the two sides of the diaphram is equalized on the engine goes back to restoring the vacumn so you can brake again.
There is an article on how stuff works:
http://auto.howstuffworks.com/power-brake.htm
PostPosted: Fri Sep 09, 2005 3:33 pm
:lol: :lol: :lol: :lol: Not that much difference :shock: I tried out my new S discs after I put them on and before I knew anything I was driving backwards down the road - a handbrakey with out using the hand brake :wink: now have S wheel cylinders and they are better :D
Sorry I forgot yours were single circuit brakes I remembered the thread about Jill's master cylinder and started thinking cause hers was dual yours was as well :oops:
PostPosted: Fri Sep 09, 2005 3:43 pm
High heel ninja
Just piss those weird arse discs off & get some cooper S ones, your inlaws should have 10 sets by now. :D
Doogie
PostPosted: Fri Sep 09, 2005 4:25 pm
Online
Yes you have to stand on them if unboosted... :lol:
If the rears are not locking up they are OK. S rears will give you even less brakes.
Discs don't stop any better than good drums, they just keep on stopping when hot, and keep stopping straight, and don't need adjustment!
Unboosted S brakes need even more pressure than your BIG 9.1" Honda ones do. But if you really are a girly wuss, fit a servo. :lol:
PostPosted: Fri Sep 09, 2005 4:37 pm
I might be wrong here, but I think servos were introduced for disc brakes and about that time drums were getting bigger with heavy pedal pressures. Size for size drums will stop beter than discs at low speeds due to the way they actually drag the lining onto the drum.
Chris
Everything I like is either
PostPosted: Fri Sep 09, 2005 4:38 pm
PostPosted: Fri Sep 09, 2005 5:11 pm
Sounds right to me. It's called "servo effect" I believe. The disadvantage with drums is fade. The heat builds up and braking power is reduced. Braking is all about converting kinetic energy (movement) into heat, and that's why discs are better. And why ventilated discs are better again. Oh, and why superfin drums are finned - to increase surface area to dissapate heat
In NZ, the engineers who certify modified vehicles get you to do repeated stops from 100km/h and it has to be less than 4 seconds or something like that.
Users browsing this forum: Bing [Bot], drmini in aust and 277 guests
