Worlds Wierdest Problem
https://www.ausmini.com/forums/viewtopic.php?f=2&t=10980
Author:  Sabreatche [ Fri Sep 09, 2005 8:12 pm ]
Post subject:  Worlds Wierdest Problem
Ok, so basically earlier today I am peacefully driving my clubby home from work, and I realise the indicators arn't working, the green lights on the dash don't flash, and they don't work externally... odd
Then something wierder started to happen. Whenever I would click on the indicator to try it out, a red light came on in the dial (I've dubbed it the "something must be up" light, as I have no idea what it does), and then both my petrol and temperature guages flatlined...wierd
Then, after a short period of time, the light goes off, the guages resest, but when I try the indicators it happens again... odd
Then I decide that the indicators are a write off, but the red light came back on again switching gears to 3rd!
Anyone have any idea whats happenening to by beloved car? is it a simple wiring/fuse issue, or do I have a poltergiest!?
Author:  aaron [ Fri Sep 09, 2005 8:31 pm ]
your indicator stalk is stuffed. try and find another one and replace it or pull it off and find the offending problem. .
Aaron
Author:  Morris 1100 [ Fri Sep 09, 2005 8:40 pm ]
Dirty fusebox. :wink:
The red light is the charge light. When it comes on the alternator (or generator) is not working. If the fusebox is dirty it can cause all sorts of problems.
Wiggle the fuses and see if the problem gets better. :P
Author:  Namibian CAMEL [ Fri Sep 09, 2005 9:58 pm ]
HEY
i was going to use that exact wording
in give your fueses a wiggle
as i have the exact problem,
and a good wiggle solves everything :wink:
so far
Author:  adeee [ Fri Sep 09, 2005 11:04 pm ]
ITs the gremlins. Did you just fix something in the mini? :lol:
Author:  LS1380 [ Fri Sep 09, 2005 11:14 pm ]
Red-Red It's the Swans......
It's a SIGN!!!!!
Author:  Dylans Clubby [ Sat Sep 10, 2005 12:24 pm ]
i had a similar issue, but it didnt happen when i changed gears! for me it was just a blown fuse. so i replaced it and it blew while i was putting it in... could be the dirty 'box, or it could be a short somewhere...
Author:  TheMiniMan [ Sat Sep 10, 2005 1:05 pm ]
yeah, it`s the fuse
easy fix
Lucas---> prince of darkness :-)
Author:  fuzzy-hair-man [ Mon Sep 12, 2005 10:28 am ]
I hada a similar issue, when I put my headlights they went on but my temperature guage went through the roof :shock: it gave me a scare I disconnected the plug at the back of the guages and plugged it back in and it was fine :? I figured some of the connections were dodgy, so maybe check your connections around the guages and indicator stalk and make sure there are no shorts etc. :wink:
