It is currently Fri Jul 18, 2025 3:28 am
PostPosted: Fri Jul 09, 2004 6:10 pm
sorry abt the huge picture....taken it before i adjust my digi cam to SMALL pixels
http://swooh.com/premium/trey/upload/107_0703.JPG
1) how much would it roughly cost to fix it up???
2) over time will those tiny rust spot actually do lotsa damage to my boot??
3) or should i just cover a carpet?
advise pls...
98 brg rover
PostPosted: Fri Jul 09, 2004 6:29 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
looks like surface rust and yes it could get worse
makka
PostPosted: Fri Jul 09, 2004 6:35 pm
makka
yeap its only surface rust...so...i should get it fixed up?...
is there like a coat of paint/or sumthing? that i could just coat it with?
98 brg rover
PostPosted: Fri Jul 09, 2004 6:59 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
rust convertor
makka
PostPosted: Fri Jul 09, 2004 7:10 pm
yeh makkas right
thats some mighty fine paint you got there... doesnt mean a thing now
rust is like a sponge. it will soak in water and air, and will rust deeper.
it just looks like little surface rust spots and you can stop the problem from getting worse,
use rough sand paper to remove most chunky flaky rust and flaking paint
buy "Rust Converter" ($17 for 500mL)
and give a couple of coats.
this will convert the rust to black stuff that will no absorb any more shite, and will give a physical barrier to prevent water getting under.
after that, just put carpet over, soft side down to stop more scratches
Inconspicuously Conspicuous
PostPosted: Fri Jul 09, 2004 11:04 pm
http://www.ppc.au.com/
These guys have everything you need.
Aaron
