rust at boot - what to do?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=1099
Author:  ryan23 [ Fri Jul 09, 2004 6:10 pm ]
Post subject:  rust at boot - what to do?
sorry abt the huge picture....taken it before i adjust my digi cam to SMALL pixels
http://swooh.com/premium/trey/upload/107_0703.JPG
1) how much would it roughly cost to fix it up???
2) over time will those tiny rust spot actually do lotsa damage to my boot??
3) or should i just cover a carpet?
advise pls...
Author:  min13k [ Fri Jul 09, 2004 6:29 pm ]
looks like surface rust and yes it could get worse
makka
Author:  ryan23 [ Fri Jul 09, 2004 6:35 pm ]
makka
yeap its only surface rust...so...i should get it fixed up?...
is there like a coat of paint/or sumthing? that i could just coat it with?
Author:  min13k [ Fri Jul 09, 2004 6:59 pm ]
rust convertor
makka
Author:  68matic [ Fri Jul 09, 2004 7:10 pm ]
yeh makkas right
thats some mighty fine paint you got there... doesnt mean a thing now
rust is like a sponge. it will soak in water and air, and will rust deeper.
it just looks like little surface rust spots and you can stop the problem from getting worse,
use rough sand paper to remove most chunky flaky rust and flaking paint
buy "Rust Converter" ($17 for 500mL)
and give a couple of coats.
this will convert the rust to black stuff that will no absorb any more shite, and will give a physical barrier to prevent water getting under.
after that, just put carpet over, soft side down to stop more scratches
Author:  aaron [ Fri Jul 09, 2004 11:04 pm ]
http://www.ppc.au.com/
These guys have everything you need.
Aaron
