It is currently Sun Jul 20, 2025 12:32 pm
 Post subject: No more Dizzy
PostPosted: Sat Sep 10, 2005 12:10 pm
8)
Been doing alot of reading RE: programable ignition systems...
Alot of guys in the UK with Turbo minis are running these and they work great..
If anyone is keen email me and I will send the info of what you will need.
All up its around a $300 Job. and you can plug your computer in and change all the maping for ignition curves..
the basis of the system runs of a MegaJolt programable unit. approx $150USD complete +$20 S&H
Then just go to a wrecking yard and find something like a ford 4cyl and gram the EDIS unit.. and your about done. 8)
I will be doing this in Evil due to the fact i need to squeeze the big front mount in and oil cooler. :lol:
I will be getting all the stuff for in in the next month and having a play with the programing..
If you wanted to go the injected path.. you can get the Maga Squirt V3 and load the squirt and spark software and can programe your injection and spark systems. :wink:
