Quick diagnostics question https://www.ausmini.com/forums/viewtopic.php?f=2&t=11054 |
Author: | LrrrrrrR [ Sun Sep 11, 2005 10:13 pm ] |
Post subject: | Quick diagnostics question |
Went to move mini and turned the key and the engine just jams. AS in it makes a noise as if it's gonna start for like a mini sec then just jams and does nothing. This sound major or something that should be easy fixed. So glad i got a mini ![]() |
Author: | min13k [ Sun Sep 11, 2005 10:14 pm ] |
um can ya be more specific ?? is the started motor turning ?? makka |
Author: | Mini Mad [ Sun Sep 11, 2005 10:17 pm ] |
Sounds like your starter motor.. Try giving it a tap to see if that works.. Check all your earths as well...on to the body on the front..and the one in the boot to the floor from the battery... |
Author: | Stuwey [ Sun Sep 11, 2005 10:47 pm ] |
Are we sure you dont have a blat fattery? Sounds to me like he's trying to explain that god-awful noise the solenoid makes. Like a really loud ticky-tick kinda noise. |
Author: | Mini Mad [ Sun Sep 11, 2005 10:53 pm ] |
That's what i think too..you'll still get the same click if the starter is gone too.. Can you push start it? |
Author: | J_A_M [ Mon Sep 12, 2005 8:10 am ] |
borrow some jumper leads (if you don't have any) and try jump starting it. Me thinks battery is low from your description..... |
Author: | LrrrrrrR [ Mon Sep 12, 2005 11:58 pm ] |
Nah not flat at all. The sterio was still pumping. I rang up my mechanic and he told me to put it in 4th and rock and back and forward because sometimes somethig (like how much notice i take with that word ![]() ![]() |
Author: | gafmo [ Tue Sep 13, 2005 7:03 am ] |
Yep the starter motor then..its just need a fix up inside |
Author: | J_A_M [ Tue Sep 13, 2005 8:36 am ] |
yea, starter gets jammed...I have seen that when Aaron and I were trying to start my motor on the ground. |
