It is currently Fri Jul 18, 2025 10:49 pm
PostPosted: Sun Sep 11, 2005 10:13 pm
Went to move mini and turned the key and the engine just jams. AS in it makes a noise as if it's gonna start for like a mini sec then just jams and does nothing. This sound major or something that should be easy fixed. So glad i got a mini :P .
PostPosted: Sun Sep 11, 2005 10:14 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
um can ya be more specific ??
is the started motor turning ??
makka
PostPosted: Sun Sep 11, 2005 10:17 pm
Sounds like your starter motor..
Try giving it a tap to see if that works..
Check all your earths as well...on to the body on the front..and the one in the boot to the floor from the battery...
PostPosted: Sun Sep 11, 2005 10:47 pm
Are we sure you dont have a blat fattery?
Sounds to me like he's trying to explain that god-awful noise the solenoid makes. Like a really loud ticky-tick kinda noise.
PostPosted: Sun Sep 11, 2005 10:53 pm
That's what i think too..you'll still get the same click if the starter is gone too..
Can you push start it?
PostPosted: Mon Sep 12, 2005 8:10 am
borrow some jumper leads (if you don't have any) and try jump starting it.
Me thinks battery is low from your description.....
PostPosted: Mon Sep 12, 2005 11:58 pm
Nah not flat at all. The sterio was still pumping. I rang up my mechanic and he told me to put it in 4th and rock and back and forward because sometimes somethig (like how much notice i take with that word :P ) gets stuck. So i did turned the beast on and it's all good so much pleased :lol: .
PostPosted: Tue Sep 13, 2005 7:03 am
Yep the starter motor then..its just need a fix up inside
PostPosted: Tue Sep 13, 2005 8:36 am
yea, starter gets jammed...I have seen that when Aaron and I were trying to start my motor on the ground.
