Ever lost a spanner in your engine bay???
https://www.ausmini.com/forums/viewtopic.php?f=2&t=1107
Page 1 of 2
Author:  supercharged 850 [ Sat Jul 10, 2004 12:48 am ]
Post subject:  Ever lost a spanner in your engine bay???
EVERYONE here knows about the Bermuda Triangle that exists within the engine compartment of every mini ever built.... It can consume ENDLESS amounts of 7/16, 1/2 and 9/16 spanners... never to be found again.
Unfortunately, you cant use this 'hidden toolkit' to add value to your car, so i have created a little device to help save the spanners.
Basically, i took an anti-static strap (a wrist band with a coiled wire attatched to it) and i secure it to to the free end of the spanner i am using. So when i accidently drop the spanner, its simply a case of lifting your hand up to pull the wire that will pull the spanner out...
Even if you cant see the spanner, the wire will lead you to it.
Good bye Bermuda Triangle!!!
Any other home made creations out there????
Author:  min13k [ Sat Jul 10, 2004 12:53 am ]
and when you are working at the back of the motor trying to do up manifold nuts under twin su.s no thanks C**T of a job as it is with out haveing some stringy pain in the frickin arse crap of a thing ....
makka
Author:  supercharged 850 [ Sat Jul 10, 2004 1:18 am ]
na, you learn to work with it, and the coil isnt so long that it gets tangled on things, its only 4 inches... no dick comments thanks
Author:  min13k [ Sat Jul 10, 2004 1:29 am ]
why did you mention penises's why would we say anything were not like that we are a nice bunch of people
are you parinoid bout the size of ya dick is it that small you have to bring it up in genral conversation
hehehehehehehehe i'll stop the lol
makka
Author:  gafmo [ Sat Jul 10, 2004 9:32 am ]
No tip on saving tools from the triangle but very please not having to work on a grass floor anymore. I also scored when Franks worked on Morris last time. A nice small flat screw driver that is perfect for the mixter scew on the HIFF44.
GGGGGoooooooaaaaaaalllllllllllllllllllllll :P
Author:  a_man_a_dog_and_a_mini [ Sat Jul 10, 2004 9:45 am ]
I can see why penises were mentioned... make one comment that can be slightly construed as a double entendre and you lot can't resist lol...
One trick I've learnt is to buy or beg an offcut of carpet to put on the garage floor. Most people think I'm weird, parking the mini on carpet, but when you realise how much time you spend lying down, reaching under, that concrete can get awfully wearing on the back. Plus, you can hear when the spanner drops out from the engine bay lol..
Author:  gafmo [ Sat Jul 10, 2004 10:22 am ]
yer I use cardboard and it soaks up those oil drips, Not that we have any :? LOL
Author:  68matic [ Sat Jul 10, 2004 1:00 pm ]
whilst driving to makkas place after a quick turn
clunk clunk clunk ching ching ching
and saw a metal thing fly off in the rear mirror
**** one of my conrods fell out
reversed and found a spanner i mustve left there after pulling the carby off
remember to count what goes into your engine bay,
the same must come out... including conrods :wink:
Author:  PhildoD [ Sat Jul 10, 2004 3:50 pm ]
To keep his spanners in each group, my old man would grab an old Arc welding rod, and break all the flux off. He'd then bend one end to form a bit of a hook. and bend the other end round so that it caught in there. Slip all the spanners on and PRESTO.
might not be that easy to understand as I've written it, but once you see it done, it's bloody simple. Obviously this is only going to work on Ring or Combination spanners
EdIT.... Since I've been using a Tag system on our toolboards at work for the last 5 years, I've found that it really is the best way to control tool use. A pain in the butt at times having to get out from under the car for each tool, but shadow boards are effective. Instantly shows if there are any tools missing.
Author:  min13k [ Sat Jul 10, 2004 5:27 pm ]
went to
rip
every
poor
c**t
off
to day and bought a set of ratchet drive spanners best investment i have ever made you know when you are being a contorsionest doing the nuts up on the manifolds these are great in stead of 10 minutes a nut it only took 1 minute a nut
makka
Author:  PhildoD [ Sat Jul 10, 2004 5:47 pm ]
Ratchet Ring Spanners. The worlds greatest tool invention. and Snapon's little ratchetless drive bar and screwdriver tips.
Author:  min13k [ Sat Jul 10, 2004 5:48 pm ]
not seen the snapon stuff got a photi
makka
Author:  PhildoD [ Sat Jul 10, 2004 6:10 pm ]
GODDAMN, I hate Snap-on Catalogues. too much crap to sort through. Just took me 20 minutes to find what I was looking for, and I KNEW what it was LOL. Anyway, they call it an "Screwdriver, Right-angle ratcheting"
I believe this link should take you there:
http://buy1.snapon.com/catalog/pro_det.asp?tool=all&item_ID=6360&group_ID=11620&store=australia&dir=catalog
Author:  min13k [ Sat Jul 10, 2004 6:12 pm ]
they look sexual
makka
Author:  68matic [ Sat Jul 10, 2004 6:14 pm ]
mmmm... nup doesnt get it up fer me
