It is currently Sat Jul 19, 2025 9:25 pm
 Post subject: dash lights
PostPosted: Mon Sep 12, 2005 6:54 pm
I've got this strange problem with my dash lights. I noticed it a few months ago then i think it went away as i haven't noticed it in a while (though i don't drive the mini at night all that much). Lately its happening again...
what happens is that when i'm accelerating or coasting, the lights in all 3 guages in the binnacle are ok, but on decelerating they go very dim and kind of ****** and i can see a faint 'glow' in the high beam light. all my other lights work fine (headlights, tacho, interior light). Last time it was happening I thought it might've been the weber backfiring into the back of the binnacle and upsetting things, but now i've got this dynamat stuff covering the hole with only a couple of gaps where the cables come through so i don't think it would be that...
any ideas what might be the cause??
TIA
Geoff
PostPosted: Mon Sep 12, 2005 8:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
bad earth
makka
PostPosted: Mon Sep 12, 2005 9:54 pm
I've seen it on my clubby where the dim adjuster switch on the right under the dash can vibrate and adjust the light level..not sure whether you have one though..
PostPosted: Tue Sep 13, 2005 9:06 am
My guess would have been the alternator is not charging properly, when you have your headlights on it is drawing more current so there is less left for the interior lights, it gets better when the revs are up because the alternator is providing more charge.
my 2 cents :wink:
Roads need more corners
PostPosted: Tue Sep 13, 2005 9:10 am
All three of the above i am thinking.
Pull the plugs off the dimmer and clens the contact surfaces.
Pull the dash out and clean up the PCB and contacts on all the lights etc etc
Put a multimeter across the selinoid and car body while running and check to see what charge is coming out of the alt. Should read 13-14v no more than 15v, otherwise the ole lucas electrics are gonna let all the smoke out....
Aaron
PostPosted: Tue Sep 13, 2005 9:13 am
Check that the bulb holders are firmly in the sockets in the back of the speedo. Had a similar problem. One socket holder wasn't clipped in properly and made contact when accelerating and cruising. But under brakes the bulb holder moved forward enough to loose contact. Once you stopped bulb holder made contact again. (Spring in wiring)
Regards
RonR
PostPosted: Tue Sep 13, 2005 10:55 am
that happened to my old van, but it only would do it when accelerating though.
not sure what was wrong with it
