It is currently Sat Aug 16, 2025 11:16 pm
PostPosted: Wed Sep 14, 2005 6:33 pm
Hello everyone was wondering if someone can please tell me where these parts pictured in the following photo come from?
As I was cleaning Granny's boot out today and I found these things and I am unsure as to where they go... Apart from the battery holder which is missing something on one end.
So any help in identifying these bits and what other part is missing from the battery holder will be greatly appreciated...
Thanks..
Opinions expressed by me are of my opinion only and are copyrighted to Kinkabell Corporation? 2006.
PostPosted: Wed Sep 14, 2005 6:37 pm
Yer Battery Holder on the right Missing one holder....I'd say the rubber is just junk other wise you can put inbetween the holden and the Battery and the Other looks like an Earth Strap :wink:
PostPosted: Wed Sep 14, 2005 6:47 pm
Ok thanks Gafmo :)..
The actual part which you said is an earth strap actually is made up of dry old rubber.. Much like an elastic band thingy.. I am wondering if this holds the batter box down in place and if so how does it attach..
Of course I will have to recondition it but I was just curious as to how it is mounted...
Also do you know what that black bit of plastic is underneath the battery holder? As it feels like cardboard that is covered with black vinyl...
Thanks..
PostPosted: Wed Sep 14, 2005 6:52 pm
It does and is bloody rare if original. There should be two hooks either side of the battery box, (the ftont one is part of the earth terminal bolt.
PostPosted: Wed Sep 14, 2005 6:54 pm
Is the Goldy Colour thing with holes in it Rubber...well no Idea then..
the large retangle piece of rubber I can only guess it goes above or below..but I just think they are missled piece lying around in your boot But I would try and find something to hold the Battery down with...all you need is another Bold and nut as per on the top right Holder
PostPosted: Wed Sep 14, 2005 7:07 pm
Ok thanks guys :)..
Yep the yellowy goldy coloured thing with holes in it I think is made of rubber. Well apart from the end clips which are metal.. It looks like it is made of rubber as it has perished very badly over the years and well you cannot straighten it out otherwise it will fall to bits..
So I will just hang onto it for the time being till I can figure out what to do with it..
Thanks..
PostPosted: Wed Sep 14, 2005 7:31 pm
The rubber strip probably sits below that metal strip to cushion it, the black rectangle probably goes under the battery in the battery box (guess) and if you have a cardboard or plastic cover on top of the battery the elastic probably goes over that, I know on Ks the cover gets knocked off pretty easy maybe that was a shortterm if rather pissy solution lol :D
PostPosted: Wed Sep 14, 2005 7:59 pm
OK thanks once again everyone..
I will look further into this tommorow...
I also gotta get a radiator over flow hose form somewhere tommorow too :? ...
PostPosted: Wed Sep 14, 2005 8:37 pm
There definitely should be a rubber strip there to hold the cardboard cover in place. Originaly these were the equivalent to today's rubber tie downs, in brown rubber. Not many original ones survive obviously as they were rubber items next to battery acid, petrol fumes, etc.
PostPosted: Wed Sep 14, 2005 8:42 pm
100% conformation on strap it goes over battery cover and holds it down, does clip into too stell eyes that are welded around top edge of battery box, I know cause our cars have them new from factory and one would assume still would be avalable,
and yes metal objecy holds on to battery under battery cover and missing one bolt, this should have an angle in it and fits onto the corner of the battery
other two bits cant help if you need a pic let us know, (of the two ther items
Monaro
PostPosted: Wed Sep 14, 2005 9:56 pm
Thanks..
Hmmm, the first picture may be Granny's teeth
I can't help you with the second one DJ, but I'm pretty sure it does take batteries :shock: :?
only the pictures have been changed to mock the innocent
PostPosted: Wed Sep 14, 2005 10:06 pm
Slow-Po
Mike, I think DJG-14U should ask Granny's previous owner about that purple instrument... :wink:
I'm surprised he hasn't already asked for it back. :lol: :lol:
PostPosted: Wed Sep 14, 2005 10:09 pm
Pops has one of those brown strap things. I wondered what it was?!? :? Cheers!
PostPosted: Thu Sep 15, 2005 9:42 am
Gee awdmoke,
Was there any need to post that picture on the forum????
I asked you about those items in confidence and you turn around and do this to me :cry: ..
Your a very naughty boy and you know what happens to naughty boys dont you..
http://www.djg-14u.com/images/naughtyboy.mpeg
BTW I ended up finding out where the purple thing goes no thanks to you awdmoke....
I dont know if I can return this either Speedy as it works so well and considering how much dust was on it I dont think the previous owner ever used it..
PostPosted: Thu Sep 15, 2005 10:10 am
the black item looks either like a heel mat or 1 half of those foldible plastic/ cardboard clip boards. what ever it is afrer market ;)
lookin for another clubby
Users browsing this forum: No registered users and 319 guests
