What Cam is this??? https://www.ausmini.com/forums/viewtopic.php?f=2&t=11364 |
Author: | =twista= [ Tue Sep 20, 2005 3:10 pm ] |
Post subject: | What Cam is this??? |
What cam is this? And how much is it possibly worth? i have no need for this cam its pretty good nick, with no grindings or nothing on it. and it has no markings or names/numbers etc |
Author: | miniimports [ Tue Sep 20, 2005 3:33 pm ] |
Post subject: | re cam |
looks like a standard 998/1100 cam probably worth a whole $5 |
Author: | =twista= [ Tue Sep 20, 2005 4:09 pm ] |
YESSSSssssss........i might just use it as a weapon |
Author: | kazjim [ Tue Sep 20, 2005 4:44 pm ] |
Am I seeing 2 cast rings up near the "Big" end ? (Opposite end to oil pump drive) Could be something special..... Doc ? J |
Author: | drmini in aust [ Tue Sep 20, 2005 5:27 pm ] |
After using max brightness and having a good squiz, I'm with miniimports- it's just a narrow lobe stocko, fuel pump drive & all. ![]() Either belt someone over the head with it, or regrind it to something useful. ![]() |
Author: | =twista= [ Tue Sep 20, 2005 5:45 pm ] |
ah mannnnnnn comon DOC cant u do better than that? what does it take to grind it to something farkin kool, that would make a mini go faster? and costs...... |
Author: | gafmo [ Tue Sep 20, 2005 6:02 pm ] |
Send it up to Graham Russell ![]() I wont quote a price...but give him a call 9630 2195 ![]() |
Author: | drmini in aust [ Tue Sep 20, 2005 7:30 pm ] |
Probably around $120-130, + return post- for an RE-13 grind. Cheap performance. Don't forget to buy a new set of cam followers to go with it... ![]() |
Author: | minicranks [ Wed Sep 21, 2005 7:23 am ] |
go to a local supplier and get a prize then next time a mini run is on take the cam down there and have a cam toss competition, for $2 you get 3 attempts to throw it as far as you can, give the winner the nice prize you were sponsered and go spend the $$$$'s that you made on throwing a cam around on a new billet or 2nd hand cam and have it ground to something decent that you can use in your mini. |
Author: | =twista= [ Wed Sep 21, 2005 9:38 am ] |
not a bad idea actaully.............. ![]() |
