click, ouch...oh man
https://www.ausmini.com/forums/viewtopic.php?f=2&t=11422
Author:  aussie [ Wed Sep 21, 2005 6:38 pm ]
Post subject:  click, ouch...oh man
so im driving home today and indicate to go into my street, and as i turn the corner and the indicator clicks back, the whole indicator stick thing decided to give up completely. now all i have is a loose stick! not only does the inicators not work now, if i put the lights on they will always stay on high beam...also the tacho wont read properly anymore and the fuel and temp guages arent working. :cry:
So, do you think it is fixable or am i up for a whole new indicator stick setup? which i know would be quite pricy.?
please help. cheers
Author:  aaron [ Wed Sep 21, 2005 6:50 pm ]
Indicator stalks on clubbies aren't too bad price wise. Someone here should have one for a reasonable price. The reason evverything is on the fritz is because the indicator stalk is more than likely earthng somewhere. If it is as buusted as you say it is. replace it.
Aaron
Author:  gafmo [ Wed Sep 21, 2005 7:37 pm ]
I would not drive it untill you have a good look around..I also agree something is earthing out.. :twisted:
Specialy as the dash is not working properly :?
I would not drive :!:
Author:  aussie [ Wed Sep 21, 2005 7:47 pm ]
yea im not going to drive until i get it fixed. ill just check it out and see what needs to be done then hopefully get it done before sunday (bay to birdwood run)
Author:  gafmo [ Wed Sep 21, 2005 7:59 pm ]
Just take the cover off and may be take the two screw off...I think with a clubby :?: as with a round and unplug the terminal :wink:
Author:  brickworx [ Wed Sep 21, 2005 8:32 pm ]
Check your fuses as well.
Author:  aussie [ Wed Sep 21, 2005 8:37 pm ]
okay so i had a good look its something to do with the spring or something. the two little metal things arent in the right place. so how do i get into the spring? what do i do? help!
Author:  aussie [ Wed Sep 21, 2005 10:09 pm ]
anyone? i wanna get this fixed ASAP....
so get a new one? can it be fixed?
Author:  brickworx [ Wed Sep 21, 2005 10:24 pm ]
there is a little metal clip that holds it all together, find it or buy a new clip.
Author:  aussie [ Wed Sep 21, 2005 10:26 pm ]
oh okay so im just missing the metal clip. :idea:
Author:  willy [ Wed Sep 21, 2005 10:27 pm ]
How are we supposed to know? lol
Author:  brickworx [ Wed Sep 21, 2005 10:30 pm ]
That is a possible solution.
bring the switch over, i've got plenty of broken switches you can look through for bits.
Author:  aussie [ Thu Sep 22, 2005 6:30 pm ]
Ive gone for the new land rover one. the old one is totally rooted, will pick it up tomorow cheers steve.
