It is currently Sun Aug 17, 2025 3:35 am
 Post subject: Grease nipples
PostPosted: Thu Sep 22, 2005 7:02 pm
Well being a bit of a lazy tit myself, I havent touched the mini's grease nippless for ages. Was wondering - is there a proper procedure for greasing them up? Oh and the old grese gets worked out with time, but is there a way of extracting it (or any need to do so)?
 Post subject: Re: Grease nipples
PostPosted: Thu Sep 22, 2005 7:13 pm
You are a bad man...the Mini needs grease :!:
Just clean up each nipple and then pump away until clean grease is seen coming through... :D
PostPosted: Thu Sep 22, 2005 7:16 pm
Yes Mike U are bad, very bad... <smack><smack>... :lol:
Mine gets done every filter change, 3000 miles, so I don't forget. 3000 miles is recommended by Mr BMC and Mr Leyland... 8)
There are 3 each side at front, 1 each side at rear, and 1 in an impossible spot on back of diff housing (magic wand & remote boxes).
Note- I give the 2 rear trailing arm ones about 15 pumps each...
Bushes are still not worn after 35 years. :wink:
PostPosted: Thu Sep 22, 2005 9:29 pm
Bad Boy mike!!! :shock: I am shocked! No wonder you didn't get very high figures on Dyno Day! Your mini doesn't love you!!! :lol: :lol: :wink:
PostPosted: Thu Sep 22, 2005 9:42 pm
You Naughty Naughty Boy
Don't forget thier is one on the Remote Also :wink:
PostPosted: Thu Sep 22, 2005 9:43 pm
Some, not all.... :wink:
PostPosted: Thu Sep 22, 2005 10:34 pm
Perhaps if they looked more like real nipples you'd get around to greasing them more often ;)
 Post subject: Ohhh Yeahhh!!
PostPosted: Thu Sep 22, 2005 10:36 pm
maybe we shouldn't outta go down that track Misty...hey..can you play Misty for me :shock: :lol:
PostPosted: Fri Sep 23, 2005 3:05 am
Oh thanks, I said I'm a tit.
And what grease should I use btw? LMM?
PostPosted: Fri Sep 23, 2005 6:59 am
No, LMM is really a CV etc grease. Use a Lithium based EP2 general purpose grease. I'm currently using Mobil Supergrease, but most others eg Valvoline, Castrol are good. :wink:
PostPosted: Fri Sep 23, 2005 8:41 pm
how do we play that?? :?
Users browsing this forum: No registered users and 394 guests
