It is currently Tue Aug 05, 2025 12:04 pm
PostPosted: Sun Oct 02, 2005 2:23 pm
i've had a bit of a problem the last couple of times driving the mini that it is hard to get into gear driving. Then its all good again, then stop and hard to get it in first or second.
I put new carpet in, so i thought maybe the carpet is too thick now when the clutch is pressed down, so i trimmed that up. went all good for a bit , then the same problem again.
so today i've gone to bleed the clutch, having a hassle getting my piece of tubing around the bleed nipple, so i thought i'd jack it up and try from underneath. thats when i noticed a shed load of oil on the bottom/back end of the gearbox and around where the remote gear joins the block. Theres no oil leaks from the top of the engine, so it must be something gone down below.
any one got any ideas of what it might be?
thanks
I dont know if this helps but the oil is all around these areas?? cant seem to see where its coming from
PostPosted: Sun Oct 02, 2005 8:18 pm
Sure it's oil & not fluid from the clutch slave cylinder?
That would explain a lot...
PostPosted: Mon Oct 03, 2005 7:41 am
the master cylinder is still full, and the oil is coming more from the front too. will post some pics today
PostPosted: Mon Oct 03, 2005 3:57 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
retrofit the pudding-stick...
oh im soz..this must not b rite..
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
