Cody Got Bling
https://www.ausmini.com/forums/viewtopic.php?f=2&t=11705
Page 1 of 3
Author:  gafmo [ Fri Sep 30, 2005 6:49 pm ]
Post subject:  Cody Got Bling
He can't be stuffed doing so his slave has to...But he is Sick...so I'm feeling Generous...
Yer good one Dody with the little Pic
Should Fit Nicley behind the Grill
Author:  GT1360 [ Fri Sep 30, 2005 6:53 pm ]
:lol: yep... thats my bling bling intercooler. :wink: 760x300x76 8)
Author:  sg [ Fri Sep 30, 2005 6:58 pm ]
you modifying it into a radiator........................ :roll:
Author:  JC [ Fri Sep 30, 2005 7:06 pm ]
ah..er....where is you think that's going to fit?
Author:  GT1360 [ Fri Sep 30, 2005 7:15 pm ]
easy fit behind the gril.. :wink: no dizzy.. edis programable ignition :wink:
Author:  drmini in aust [ Fri Sep 30, 2005 8:17 pm ]
Hmmmm so where's the oil cooler go, you might need one with all this power heating the oil up! :P
Author:  Stuartminidlx [ Fri Sep 30, 2005 8:24 pm ]
good point doc. i am thinking of maybe a custom made largers oil cooler or twin 13 row coolers. i think i am goin to use a s13 intercooler. also
Author:  GT1360 [ Fri Sep 30, 2005 8:35 pm ]
oil cooler will go out the side. I cot no inner gaurds remember.. can mount on the brace bars. :wink:
Author:  kazjim [ Fri Sep 30, 2005 8:37 pm ]
And Altenator, and Starter, and . . . .
Been there.. no room ......
Sorry mon, it no fittee .....
Unless you move your engine back about 2" then there may just be enough squeeze . . .
J
Author:  GT1360 [ Fri Sep 30, 2005 8:38 pm ]
with no dizzy there is room :)
Author:  kazjim [ Fri Sep 30, 2005 8:54 pm ]
You have a Starter Motor in there ?
Hmmmmmmmm
cant fit a pack of cards between my chassis rail and the starter......
J
Author:  JC [ Fri Sep 30, 2005 8:55 pm ]
I'm certainly not a defeatist but it don't rate your chances. I'll be glad to be proven wrong. Where are you mounting the turbo?
Author:  GT1360 [ Fri Sep 30, 2005 9:08 pm ]
turbo down the back of the block...
it will fit.. TRUST ME. :wink: nothing like a little cutting and shuting :twisted:
Author:  drmini in aust [ Fri Sep 30, 2005 9:13 pm ]
My S oil cooler has only 3mm clearance to the Lucas starter, and it's nowhere near 75mm thick. I had to pack the grille out to clear. I used surplus Pulsar dizzy drive dogs... because I can!:lol:
Author:  GT1360 [ Fri Sep 30, 2005 9:20 pm ]
Page 1 of 3 All times are UTC + 10 hours
