It is currently Sun Aug 03, 2025 1:53 pm
 Post subject: Cody Got Bling
PostPosted: Fri Sep 30, 2005 6:49 pm
He can't be stuffed doing so his slave has to...But he is Sick...so I'm feeling Generous...
Yer good one Dody with the little Pic
Should Fit Nicley behind the Grill
PostPosted: Fri Sep 30, 2005 6:53 pm
:lol: yep... thats my bling bling intercooler. :wink: 760x300x76 8)
PostPosted: Fri Sep 30, 2005 6:58 pm
you modifying it into a radiator........................ :roll:
I got nuthin......................
PostPosted: Fri Sep 30, 2005 7:06 pm
ah..er....where is you think that's going to fit?
PostPosted: Fri Sep 30, 2005 7:15 pm
easy fit behind the gril.. :wink: no dizzy.. edis programable ignition :wink:
PostPosted: Fri Sep 30, 2005 8:17 pm
Hmmmm so where's the oil cooler go, you might need one with all this power heating the oil up! :P
PostPosted: Fri Sep 30, 2005 8:24 pm
good point doc. i am thinking of maybe a custom made largers oil cooler or twin 13 row coolers. i think i am goin to use a s13 intercooler. also
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
PostPosted: Fri Sep 30, 2005 8:35 pm
oil cooler will go out the side. I cot no inner gaurds remember.. can mount on the brace bars. :wink:
PostPosted: Fri Sep 30, 2005 8:37 pm
And Altenator, and Starter, and . . . .
Been there.. no room ......
Sorry mon, it no fittee .....
Unless you move your engine back about 2" then there may just be enough squeeze . . .
J
PostPosted: Fri Sep 30, 2005 8:38 pm
with no dizzy there is room :)
PostPosted: Fri Sep 30, 2005 8:54 pm
You have a Starter Motor in there ?
Hmmmmmmmm
cant fit a pack of cards between my chassis rail and the starter......
J
PostPosted: Fri Sep 30, 2005 8:55 pm
I'm certainly not a defeatist but it don't rate your chances. I'll be glad to be proven wrong. Where are you mounting the turbo?
PostPosted: Fri Sep 30, 2005 9:08 pm
turbo down the back of the block...
it will fit.. TRUST ME. :wink: nothing like a little cutting and shuting :twisted:
PostPosted: Fri Sep 30, 2005 9:13 pm
My S oil cooler has only 3mm clearance to the Lucas starter, and it's nowhere near 75mm thick. I had to pack the grille out to clear. I used surplus Pulsar dizzy drive dogs... because I can!:lol:
PostPosted: Fri Sep 30, 2005 9:20 pm
