It is currently Fri Jul 18, 2025 2:48 pm
How many people will I need to get over to lift a motor on box?
Just one - I am freakin H U G E ! 0%  0%  [ 0 ]
Two - One either end 75%  75%  [ 9 ]
Three and nothing less 25%  25%  [ 3 ]
Four - accountants and IT nerds 0%  0%  [ 0 ]
Total votes : 12
 Post subject: Lifting a motor
PostPosted: Fri Jul 16, 2004 9:21 am
How many people will I need to lift a motor, on box. No carb, or alt, but it has manifold and dizzy installed?
I have to move one, not too far away from where it is, but I need to know how many people to invite over, for say a BBQ, and then tell 'em...."Hey, while you are all here....." :lol:
PostPosted: Fri Jul 16, 2004 9:25 am
I use a skate board to move a mini motor/box around- still need 2 people.
Olly.
PostPosted: Fri Jul 16, 2004 9:42 am
Just don't break your back, or worse, drop it on yer toes! :?
PostPosted: Fri Jul 16, 2004 11:58 am
yeah two should do it.....and the skateboard is a good idea too.....thats how my old man and i shift donks around
PostPosted: Fri Jul 16, 2004 12:20 pm
Go to Bunnings/ Super Cheap etc and buy one of those furniture trolleys with the big knobby pneumatic tyres. Usually less than $50.
They are fantastic for moving Mini engines around, and you can use them to move house as well! 8)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jul 16, 2004 2:00 pm
The block and head, could comfotably be carried by two. Really dunno bout the g/box as well. Anything bigger, and I'd be using an engine hoist hehehe.
Every engine change I do, I use a forklift. different engines but hehe
PostPosted: Fri Jul 16, 2004 4:25 pm
glad to hear im not the only one who uses skateboards :D
2 people should be able to do it, id reccomend a trolley of some kind, very useful (or a skateboard)
PostPosted: Fri Jul 16, 2004 8:15 pm
Just ask a mate of mine to give you a very comical recreation of my attempts to get a full power unit (complete with ancillaries and oil) off a trailer. Chris had a good grip on his end, and my end plummeted to the ground in about 1 split second :shock: Glad my foot wasn't in the way! Two stronger people can lift an engine easy. I'm just not prime candidate. I don't drive a Mini for nothing you know....
Anto.
PostPosted: Sat Jul 17, 2004 2:47 am
In my experience, it takes 20 people to shift a motor....
You and another to lift it, then the other 18 to help watch...
PostPosted: Sat Jul 17, 2004 9:06 am
LMFAO, how true is that SC850.........
I know how ya feel, and all that extra advice while you've got it jammed on your agates, really helps too.
PostPosted: Sat Jul 17, 2004 12:23 pm
Well, in my experience. One person can lift the engine/gearbox for a short way or to lift onto the back of a ute. Two people can do it easily and if you're doing something fiddly, such as lowering the body onto the subframe, three people - two to lift, one to guide is ideal.
When I was fixing up my old engine, I made a little trolly from a thick sheet of particle board and 4 rolling wheels brough from bunnings
You're only supposed to blow WHAT off?
PostPosted: Sat Jul 17, 2004 1:27 pm
to add on to that, in my exprience, i think it takes 9 people to do it
2 to lift and 7 to say what a "siccck cunnt"
98 brg rover
PostPosted: Sun Jul 18, 2004 8:03 pm
One person (with trolley or engine crane)
Two people (with beer, and trolley or engine crane)
Two people (with steel cap boots)
Three people (without steel cap boots)
Watch out for SuperCheaps adverts as I got my trolley on special for $20 and it works great. Saves having to wait for someone to come home to move an engine!
HRS
