Steering Rack Boot Lubricant? https://www.ausmini.com/forums/viewtopic.php?f=2&t=1175 |
Author: | Lillee [ Fri Jul 16, 2004 11:18 am ] |
Post subject: | Steering Rack Boot Lubricant? |
Quick question, what do i need for the steering rack boot? SAE90 Hypoid oil? or can I use regular Castrol LMM? (already got the stuff) I think it's currently got the Hypoid oil in it, looks runny not viscous like regular grease... Cheers, Chong |
Author: | PhildoD [ Fri Jul 16, 2004 1:57 pm ] |
I'd use the SAE90 Hypoid oil. Manual gearboxes, differentials, and steering boxes rely more on the high pressure oil being a thin film between the gear teeth for their lubricating property. Grease may be too viscous to remain in contact with all of the teeth at once. |
Author: | Lillee [ Fri Jul 16, 2004 2:24 pm ] |
Thanks mate! One more question since I have your attention, should I get metal boot kit ties? the ones that came with the ones from Karcraft are plastic cable ties! ![]() Ta, Chong |
Author: | PhildoD [ Fri Jul 16, 2004 3:16 pm ] |
I think ya got ripped off. I think the metal ties are better for longevity. It doesnt take long once the CV boot has fallen off to stuff the CV's. I make it a rule that if the boot comes off, the entire joint gets regreased. So I prefer that the boot doesnt come off. I recently did all four joints (2 CV's, and 2 inner potjoints). I bought the outers from a mini mechanic locally, and got one with metal tiestraps, and one with panduits(cable ties). I got the inners from another joint, and got both with metal tie straps. I wont be going back to the mechanic. he tuned my car up supposedly, yet the dizzy was free to turn, and it was running like a pig when I got it back. NOT HAPPY There is also a method of wrapping two loops of wire around them and tying them off called lockwiring. Easier to use the tie straps. Just remember that whatever you use, make sure the tail of the strap goes opposite the direction of the CV travel, to stop it loosening off |
Author: | Lillee [ Fri Jul 16, 2004 3:22 pm ] |
Righto, will be using metal tie straps! I thought that the plastic ones seemed bodgey! I got ripped big time, I assumed metal tie straps with this kit ![]() Looks like I can't avoid a visit to "the expensive mob"... Cheers PhildoD Chong |
Author: | PhildoD [ Fri Jul 16, 2004 3:49 pm ] |
Hey Lux, dont go too silly. Go to any CV joint, or suspension joint in town. Ya should be able to get the metal straps at any of them for a dollar or two each Somebody should be able to help ya out with them. They're a generic size, and ya just cut the tail off to suit |
Author: | drmini in aust [ Fri Jul 16, 2004 7:26 pm ] |
I believe Subaru ones are the duck's guts of metal straps. Dunno $$ or p/no. ![]() |
Author: | Lillee [ Fri Jul 16, 2004 10:25 pm ] |
Duck's Guts??? ![]() |
Author: | drmini in aust [ Sat Jul 17, 2004 7:44 am ] |
It means the same as `dog's dangles', ie superbloodyrippermate... ![]() |
Author: | PhildoD [ Sat Jul 17, 2004 9:08 am ] |
Dog's dangles, as taken from the term Dogs Bollocks of the Pom's(which means it's the best). Directly opposite to plain BOLLOCKS which is just utter crap. |
